How do the Cold Air Intakes perform
Thank you
I did add a Vararam intake though with a tune. HP and Torqoue up across the board. At peak up 16hp and torque 12 Ft lbs. But that is not the real story IMO. The gains don't fall off after peak and get wider.
Thank you
i have tried a variety of filter/intake ducting mods but unfortunately i don't own my own dyno so i can't provide 'hard data' to support my pposition.
there is also conjecture that some gains will not show up on the dyno simply due to the difference in airflow, road vs. fan.
imo/experience,
simply changing the filters and using the stock airboxes/ducting provides the least improvement, if any.
replacing the filters, cutting the shroud, flipping (aiming the boxes through the shroud) and swapping (left for right) the airboxes and sealing the opening seems to provide the best homemade gains, on par with some aftermarket systems.
the k&n, halltech style provide some airflow improvements.
the callaway, lingenfelter style provide better airflow gains and modest ram-air gains.
the vararam seems to provide the most airflow and ram-air gains.
http://forums.corvetteforum.com/show....php?t=1434941
342 Stock
368 Hallteach and no CAI
378 Lingenfelter CAI
The most obvious was the gains I got at mid range with the LPE CAI.
This the dyno from my 403 with the LPE CAI
http://forums.corvetteforum.com/show....php?t=1524643
Hope this helps.
Hope this helps.
http://forums.corvetteforum.com/show....php?t=1526972
lowering your IAT helps a LOT! See out how much timing gets pulled.
But where are the post with actual data showing a reduction in IAT. I was surprised how well the stock intake performs. The Halltech did seem to drop the IAT faster than stock. The only other scans I have seen for aftermarket airbridges, the IAT is higher at speed but it will decrease from peak faster than both the stock and the Halltech will.I have asked this question in post where the manufacturers were active but I have never received a response from them.
342 Stock
I've seen people get those gains with headers, but not just an intake!
Anyone? I know there are a lot of guys with logging software now.
imo/experience,
