Muffler Or Not?question
Old Oct 18, 2006 | 08:12 AM
not08crmanymore's Avatar
not08crmanymore
Default Muffler Or Not?question
Is that resonator thing in the middle of the CORSA X-PIPE a muffler??Thanks.
Old Oct 18, 2006 | 10:58 AM
haljensen's Avatar
haljensen
Terminology. A resonator is pretty much the same thing as what used to be called a "glass pack" muffler.
Resonator = straight thru muffler (no baffles).
Old Oct 18, 2006 | 11:55 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Resonator
A small auxiliary muffler that assists the main muffler in reducing exhaust noise.
Resonators
On your typical cat-back exhaust system, you'll see a couple of bulges in the piping that are apparently mini-mufflers out to help the big muffler that hangs out back. These are called Helmholtz Resonators and are very similar to glasspacks. The main difference is that firstly, there is no sound-absorbing fiberglass or steel wool in a Resonator. And secondly, their main method of silencing is the reflective principle, not absorption. An easy way to tell the difference between a glasspack and a true Helmholtz Resonator is to "ping" one with your finger. A glasspack will make a dull thud, and a true Resonator will make a clear "ping!" sound.*
* http://nsxprime.com/FAQ/Miscellaneous/exhausttheory.htm
Old Oct 18, 2006 | 05:06 PM
not08crmanymore
Default sound
So,a resonator will to some extent,muzzle sound.Thanks.
Old Oct 19, 2006 | 01:51 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I'm not sure what 'muggle' means...but resonators are there to change and probably quiet the sound to some degree.
Old Oct 19, 2006 | 01:59 PM
not08crmanymore
It was MUZZLE that I meant!!SPELLCHECK IS MY FRIEND,UNLESS I forget to use it!
To Muffler Or Not?question
