Ignition with C6 start button
Old Oct 18, 2006 | 11:31 AM
z060ntrack's Avatar
z060ntrack
Default Ignition with C6 start button
How do you turn just the ignition on (I want to bleed the brakes with ABS activated) with the start button?
Old Oct 18, 2006 | 11:46 AM
Cowboy1963's Avatar
Cowboy1963
Hit the start button without depressing the clutch pedal.
Old Oct 18, 2006 | 06:33 PM
Brett Hunter's Avatar
Brett Hunter
I have never tried the way that Cowboy1963 posted but you hold down the bottom of the button (as if turning on acc mode) for about 5 seconds. This will put the car in ignition on mode without engaging the starter. Make sure that you hold it long enough, you should see the check engine light come on since the engine is not running.
Old Oct 18, 2006 | 06:43 PM
BBISHOP660's Avatar
BBISHOP660
yeah...i think it's 10 seconds and it goes into run mode.
Old Oct 18, 2006 | 06:51 PM
Brett Hunter
That sounds right. I didn't take the time to look it up and I was going from memory.
Old Oct 18, 2006 | 11:01 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Oct 18, 2006 | 11:14 PM
Vet's Avatar
Vet
I've seen "10 seconds" posted here in the past but I'm sure mine takes less than 10 seconds. I think mine only takes about 5 seconds or so. I just did it a few hours ago and it definitely did not seem like 10 seconds. Maybe I'll time it next time Get out the digital stop watches... we can see who's is the fastest
Old Oct 19, 2006 | 01:39 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
How are you gonna activate ABS? Got a Tech II?
Old Oct 19, 2006 | 07:56 AM
z060ntrack's Avatar
z060ntrack
No I don't have a Tech II but have had good results with doing a bleed sequence with ignition on (ABS activated / cycled) and then a bleed sequence with the ignition off on C5.
Thanks for everyones reply that is just the info I needed.
To Ignition with C6 start button
