Diablo Predator Tuner
Old Oct 18, 2006 | 08:52 PM
mfinocc's Avatar
mfinocc
Default Diablo Predator Tuner
My Diablo Predator Tuner is telling me part number not found when I connect. Diablo says that the car needs to be flashed with the latest software from the dealer. I requested this at the last oil change and I'm still getting the same message. Do you think dealer just feed me a line of when they said they re-flashed? Is there another way I can resolve this?
Old Oct 19, 2006 | 01:22 AM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Yes They Did the Same BS with me..First time...Then When i brought it back i told them The car had Some bulletin problems..I forgot which ones i told them...I Think one was the Fuel Gauge ..Cant remmber its been awhile...
Old Oct 19, 2006 | 07:59 PM
mfinocc's Avatar
mfinocc
Do you know if you ECM programming is # 12613186? This is the latest version that addresses the potential battery run-down situation.
Old Oct 19, 2006 | 08:33 PM
BEZ06's Avatar
BEZ06
I'm not clear from your 2 posts - did they reflash you with that # above?
If so, and Diablo tells you need the lastest flash from GM and you actually have it, then you may have an older version of software in your Predator.
When you start up your Predator, what version of .crom software does it say is loaded in the Predator - is it 7r99?
According to the Diablo website
( http://www.diablosport.com/index.php...display&pid=68 )
there is a new version of the .crom software : 8r01
It sounds like that if you do have the 12613186 flash, you may need to upgrade your Predator to the 8r01 version.
Bob
Old Oct 19, 2006 | 08:41 PM
mfinocc's Avatar
mfinocc
Bob
You are correct, I do have version 7r99. Let me try the update. Thanks!
Old Oct 19, 2006 | 09:23 PM
BEZ06's Avatar
BEZ06
Do you have the cable (9-pin serial cable, or probably a serial/USB cable if you don't have an old computer with a serial port)?
Do you either have a laptop you can take out to the car, or a power adapter to power up your Predator inside?
The instructions and the required download and installation software are on that Diablo website in the above post.
Any questions, post here or PM.
Bob
To Diablo Predator Tuner
