Rear carpet removal - how?
Old Oct 23, 2006 | 09:26 PM
jsk96z28's Avatar
jsk96z28
Default Rear carpet removal - how?
Any information on how to remove the rear carpet so i can install some b-quiet? pics would be great, but any info would be appreciated. thanks
Old Oct 23, 2006 | 10:10 PM
jogar80's Avatar
jogar80
The carpet covering the latching mechanism for the hatch has 4 snaps that run across the top. Pull those out, then just yank the whole back piece off. The bases for the targa do not need to be removed, just pull the carpet out. Then the floor. Start with the storage bins, they have a plastic frame around them so just pill on it and it snaps out. The hooks on the wheel-wells for the targa have a plastic base that just snaps off. After you pull those off, you can pretty much just yank the whole carpet out. The carpet is tucked in under the plastic where the rear speakers are. Dont be afraid to just tug on it and pull it out from under the plastic. Its just the edges of the carpet so when you reinstall just use a screwdriver to push it back under the plastic. Hope this makes some sense!
Old Oct 24, 2006 | 06:58 AM
jsk96z28's Avatar
jsk96z28
Originally Posted by jogar80
The carpet covering the latching mechanism for the hatch has 4 snaps that run across the top. ... Hope this makes some sense!
Thanks, appreciate it!!!
Old Oct 30, 2006 | 10:56 PM
jdster99's Avatar
jdster99
Cruising
Default front carpet removal
Any idea how to get the front carpet pieces out. i dont wan to rip the carpet . i have tugged on those tabs but no use???
2007 convert
Old Nov 4, 2006 | 11:00 AM
jsk96z28's Avatar
jsk96z28
No wonder there is so much noise from the bullets, there is nothing back here but thin plastic and fiberglass.
Old Nov 4, 2006 | 09:50 PM
excessive81's Avatar
excessive81
told you so....was real suprised myself!!! whole car is that way!! it is added weight but i will skip a meal
Old Nov 4, 2006 | 09:57 PM
excessive81
oh and for the front pull the seats, console,door molding, kick panels and losen b piller panels to get carpet out.
To Rear carpet removal - how?
