gears grinding when cold
Should I take the thing back in...I took it in once because I couldn't get it into first or out of first. They "adjusted the pressure plate" - Whatever I don't even know of an adjustment that could be made on the pressure plate...any comment will help; thanks
Sounds like they be blowing SMOKE up yer chute. I'd love to see the comments on the warranty service ticket for that "adjustment".
There was a TSB for 05 MN6's, that involved replacing the 1st gear syncho's, but since difficulty getting into 1st was documented in the owners manual - I guess that makes it a FEATURE, not an ISSUE...
Rick
Yeah, I still can't get it into first gear. It happens at almost every red light. Them: "I see what you're talking about, but I don't see it as a problem". Me: "you pay the damn payment every month and tell me that 'it's not a problem'."
Yeah, It's a late '05 ( i think July '05 was the build date) - I guess I'll call tomorrow to make an appointment at another dealership. Thanks...Hopefully it'll go well.
Tremec trannies are used in more than just GM cars. Alot of the issue is the shift rod geometry with a rear mounted tranny. GTO's have the same tranny, and it shifts completely different - though a common problem alot of GTO guys have when "quick shifting" is going for the 3-4 shift and hitting 2nd by accident (with DISASTEROUS RESULTS - like 8500RPM over-revs).
I've commented before, out of all the manual trannies I've driven (american, german, ***), I'm totally dissapointed by the way the vette shifts...
Rick
Rick
Not that they might not be making stuff up, but if this was set wrong originally or got out of whack it could cause problems - like perhaps the clutch not disengaging fully.
Regarding it being hard to stuff into gear when cold, mine is a bit stiff too until it warms up. I wonder if the Royal Purple Synchromax would help with this.
Not that mine was as balky as yours, but just by changing out the fluid, shifting and clutching is much easier and smoother. My clutch fluid looked like hell after 2 years of inattention.
Do a search for Ranger's procedure.
Basically sucking out most of the fluid with a turkey baster or syringe, replacing the fluid, hammering the clutch (car off) a bunch a times, then redo the whole process until the fluid stays clear.
The key, IMO, is the fact that the balky shifting goes away when the transmission warms up...if it were a clutch problem, I wouldn't expect it to get better as it warmed up. ALL C6 Corvette Tremec T-56 transmissions have varying degrees of balky shifting when the fluid is cold.
Last winter, even though I live in a warmer climate, I experienced shifter "drag" from first to second, and second to third, and, sometimes, minor gear noise on engagement. Some owners have gotten relief with mileage; others say no after 10K miles. Some have changed to synthetic ATF (Must meet GM's H Spec), and swear that the shifting is smoother.
I recognize it's the nature of the beast, and I plan to take no action until I believe it's abnormal. I'm waiting to see how it is this winter...it's supposed to be cold here, so it should get a good test.
Shifts are a little stiff and grindy when cold. Not really grinding, but you can feel the gears spin up and clash a bit going in. Normal, nature of the beast. All my MN6s have done that, put in some synthetic - that will help some. I used Amsoil with good results. Cold shifting, give the throttle a little blip before going into gear. This will match the gear rpms and shift smoother when cold.
My first gear shifts when cold are easier and smoother now, as opposed to previous with 2 year old ugly fluid.
Anyhow, I like things perfect so I wanted to try synthetic AFT & see if that would help. I tried Mobil 1 AFT and the shifts smoothed a bit when the fluid is cold. Again, all OK when things are fully warm.
Then a couple of days ago, I finally tried RP Synchromax and I can say the shifts are noticably smoother when cold. While still not perfect in my view, a lot better than where I started from.
I hate to be cynical, but I trust that when I do get it back, it will be at best in the same condition in which I gave it to them. I am really losing all faith in the General. I spoke to the Corvette specialist at the dealership and he said "You just can't have performance and reliability man...you just can't have it both..." That kinda pissed me off...
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Although it's been colder, my transmission seems noticeably better this year, but I now make my first few shifts very slowly. For example, I shift from first slowly to neutral, pause, then slowly into second. By shifting slowly, I'm experiencing just a muffled "click" or two as the second and third gears engage. After several miles are driven, the problem goes away completely.
Since this temporary inconvenience is minor and seems to be improving, I don't plan to change my transmission fluid.
