Which mode for Drag Strip?
Old Oct 26, 2006 | 09:42 PM
FOREST's Avatar
FOREST
Default Which mode for Drag Strip?
I'm headed to the track on Sunday with my C6 M6 with no Slicks
Which driving mode should I use? competition driving mode, traction off only or all off.
I have BF Good. Comps on the Chrome wheels i put on the car when I got it. (took off the factory silver rims and runflats)
Since I have these street tires, I shouldn't do the burn off, right?
Give me some advice
Old Oct 26, 2006 | 09:51 PM
NineBall's Avatar
NineBall
all off.
drive around the water if possible
no burnouts needed for street tires
do a peel out up to the line if you are forced to drive thru the water.
shift as close to redline as possible
LIFT on the throttle if you feel any wheelhop. Or snap-crackle-pop will happen to the rearend.
Old Oct 26, 2006 | 09:57 PM
FOREST's Avatar
FOREST
I've been once before and the first run i ran in comp. mode, got the wheel hop in second and when i shifted to third, the car slide sideways. The track is pretty slick. So I just ran it in the normal everything on mode the rest of the night.
Old Oct 26, 2006 | 10:59 PM
Arthur6's Avatar
Arthur6
Yea, these cars have a lot of power, be careful & have fun
Old Oct 26, 2006 | 11:10 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
Comp mode works best for me.
Old Oct 27, 2006 | 06:19 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by NineBall
all off.
however, if you're not familiar with the track i'd recommend a couple of runs with everything on, then as you learn how your car is responding to the track try comp. mode. then once you've got a real good feel for the track you can think about all off. just be warned, she is a whole new animal when she's in all-off mode.
Old Oct 27, 2006 | 07:29 AM
yell03's Avatar
yell03
I would turn TC OFF, but leave AH ON.
Just ONE press of the button.
This will allow you all the wheelspin you need, but if you are going down the track you will have the benefit of AH to help save your butt if you hit oil or fluids.
I ran my 2006 C6 manual with just TC off and it did well with a 12.55@115.85.
I ran my 2005 C6 Vert A4/3.15 with everything OFF to a 12.57@110.67, but with an automatic you basically point it straight.
If I had to run the auto again I would just do TC off and leave AH ON.
Howard
Old Oct 27, 2006 | 09:49 AM
Wingrider's Avatar
Wingrider
"I would turn TC OFF, but leave AH ON.
This will allow you all the wheelspin you need, but if you are going down the track you will have the benefit of AH to help save your butt if you hit oil or fluids."
I am new to this, but if you are spinning wheels, buring rubber, does this not hurt your track time? I asked something like this in an earlier post. I have headers on my 2006 A6, and if I floor it in competition mode, I can burn a lot of rubber. Problem, would this not be a negative in 1/4 mile run times?
Old Oct 27, 2006 | 09:56 AM
yell03's Avatar
yell03
Wingrider -
You don't want to spin your tires too much, but....
The TC ON will SLOW you down by cutting power and applying the brakes, you are better off managing the throttle yourself with TC OFF.
Howard
Old Oct 27, 2006 | 11:51 AM
FOREST's Avatar
FOREST
Thanks Howard for the input. I let you know monday how it went. Just installed kooks headers and high flows and hoping to get the vararam in today. Was hoping to have it tuned before going to the track, but will have to wait til next time.
Forest
Old Oct 27, 2006 | 12:55 PM
Wingrider's Avatar
Wingrider
Thanks Yello3. I guess for launch technique I will have to learn by trial and error. I guess that is half the fun.
Old Oct 27, 2006 | 02:05 PM
yell03's Avatar
yell03
OK guys,
bring back some 11s and 12s!
Howard
Old Oct 27, 2006 | 02:29 PM
FOREST's Avatar
FOREST
Originally Posted by yell03
OK guys,
Howard
I'LL BE HAPPY WITH MID TWELVES I THINK HOOKING WILL BE THE KEY.
Old Oct 27, 2006 | 07:25 PM
Angelo C6's Avatar
Angelo C6
What exactly does the "competitive driving" mode do differently from having the active handling on and traction control off?
Old Oct 27, 2006 | 07:28 PM
yell03's Avatar
yell03
Competitive Mode uses a LESS INTRUSIVE form of AH.
Howard
Old Oct 28, 2006 | 06:47 AM
Zig's Avatar
Zig
Howard
and NO traction control.
Old Oct 28, 2006 | 07:45 AM
yell03's Avatar
yell03
He asked how it differed from having AH On and TC off, so I just gave him the simple answer.
I was being lazy
Thanks for adding that, I was rushing during a commercial.
Howard
To Which mode for Drag Strip?
