Z51 Shock Removal HELP
Old Oct 28, 2006 | 11:26 AM
aggie88's Avatar
aggie88
Default Z51 Shock Removal HELP
Can't seem to get enough clearance to slide the OEM shock out of the front. I even pulled the sway bar off but the A arm doesn't drop low enough to clear the shock. Any tips?
Also - any tricks with removing the rear shocks?
Old Oct 28, 2006 | 01:57 PM
big bollas's Avatar
big bollas
You just have to push up on the shock and then twist the bottom of it and it will come out. You may try jacking the A-arm up to compress the shock and then let it down and twist it out.
Rear shocks are alot ezr to do ,just unbolt and push up on the shock and twist it out
Old Oct 28, 2006 | 02:05 PM
aggie88's Avatar
aggie88
Ok, that is S.O.P. for a front shock on most cars, just want to double check if there was an easier way. The problem I am seeing is that if I compress the shock upwards, the rubber grommet around the top gets pushed back into the frame and requires some time to get it back out. Guess I just have to work as fast as I can before the shock extends. That Z51 shock is a lot stiffer to push in than I thought. Thanks!
Old Oct 28, 2006 | 02:52 PM
rfopt's Avatar
rfopt
You can use big zip ties. You can jack up the supension at the bottom on the outside to compress the shocks. Make sure the bolts are out of the shock at the bottom. Then wrap a few zip ties around the compressed shock. When you lower release the suspension the shocks will still stay compressed while the rest of the suspension lowers. The zip ties can hold the pressure.
Old Oct 28, 2006 | 03:47 PM
Dave_Busch's Avatar
Dave_Busch
All of the suggestions will work. Also if you unbolt the lower ball joint, the lower control arm will drop and give the shock room to slide down and out.
Old Oct 28, 2006 | 04:12 PM
timd38's Avatar
timd38
That's how I do it.
To Z51 Shock Removal HELP
