dyno question
Old Nov 2, 2006 | 11:35 PM
dan-t's Avatar
dan-t
Default dyno question
Is it normal to run a big fan in front of car during dyno? does that skew #'s..base run 311 no fan tune alittle next run 328..more tuning fan turned on and 345hp on that and next 2 runs...is the fan turning on helping these #'s...34hp seems high for a tune...dynojet was used..all about 10 minutes apart..ls2edit was software..thanks for your help..car is a6 stock except magnaflow mufflers..
Old Nov 2, 2006 | 11:36 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Originally Posted by dan-t
Is it normal to run a big fan in front of car during dyno? ..
Yes
Old Nov 2, 2006 | 11:38 PM
dan-t's Avatar
dan-t
did that help #'s with 2nd to 3rd run?
Old Nov 3, 2006 | 12:49 AM
glennhl's Avatar
glennhl
He turned the fan off for the first run? Sounds like a tuner's trick to me. To give you an example, I ran back to back pulls with my stock A6. Both pulls had the fan on. First run I made 334 rwhp, then on the second pull the car made 316 rwhp because it got a little hot and pulled some timing. The LS2's pull timing for inlet air temps of over 86F and coolant temps above 212F.
Why would anyone leave the fan off? The car is going to overheat without air flow through the radiator. So, it's possible that they did it on purpose to make the car dyno lower on the first run on purpose in order to impress you with all the power they picked up for you.
Mind you, I still think you made good horsepower with the tune, but I'm betting you only picked up about 10 rwhp.
Old Nov 3, 2006 | 12:53 AM
cbrf4i1's Avatar
cbrf4i1
Old Nov 3, 2006 | 12:56 AM
dan-t's Avatar
dan-t
thats what i was thinking..he acted like he forgot. he was running around like crazy when i got there..he is a new friend and long time friend of friend...great guy...first 2 pulls were no fans 3rd is when he turned it on..
Old Nov 3, 2006 | 06:38 AM
Fore58's Avatar
Fore58
The average for a good tune is between 10-15hp.
Old Nov 3, 2006 | 10:27 AM
haljensen's Avatar
haljensen
No fan can approximate the air flow around the car on the road or track. But; A fan on the Dyno should result in slightly higher HP readings by reducing coolant and intake temps.
Old Nov 3, 2006 | 11:37 AM
dan-t's Avatar
dan-t
thanks guys...well 345 hp 338 tq.. how are those numbers for a6..?? average?
Old Nov 3, 2006 | 12:39 PM
bunk22's Avatar
bunk22
Around 2 years ago, a local dyno guy did the same thing to my 03 Cobra. He claimed it was how some company's might gain power from simple things like a cat-back. He did a dyno run without the big fan on and immediately did a back to back run with it on. There was around a 20rwhp difference between the two (with the fan on, the power being higher of course).
Old Nov 3, 2006 | 12:44 PM
dan-t's Avatar
dan-t
thanks so more like 14hp instead of 34 ..good info..thanks again
Old Nov 3, 2006 | 02:07 PM
glennhl's Avatar
glennhl
I made 334 with my stock A6, so I think your numbers are GREAT!
Old Nov 3, 2006 | 02:33 PM
dan-t's Avatar
dan-t
345 after tune so close to yours stock..glad to see mines not a turd..thanks again
Old Nov 3, 2006 | 02:55 PM
BLU-BY-U's Avatar
BLU-BY-U
little story here...I had at the time a cam "only" 02 z06 with a package from vendor A. Had it for several months and it dynoed 410ish SAE just about every dyno shop I went to. I just happened to be at vendor "B" one day for a dyno day. My car came up for dyo and it was obvious a bump stick was there at idle. The vendor B guys kept asking who's cam I was running and I just flat told them vendor A.
Well...next thing I know vendor B is having "issues" dynoing my car. Said "it's breaking the tires loose on the drum...." and they kept jacking around until my coolant temps must have been 225. They then got two big dudes to "lean" on the rear of the car to "keep it from breaking the tires loose..." Now mind you, this a 410 to the wheel car - lol
long story short, it dynoed about 395 that day and they made sure everyone present knew who's cam package I had. Never went back to that shop ever again...and quite frankly told them they were full of poopoo for that stunt. :o
Old Nov 3, 2006 | 03:38 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I completely agree with glennhl, and some of the other stories are exactly why I don't like dynos. Yes they are helpfull tuning tools and good to get an idea of the powerband but people put far too much stock in dynos. Like some of you posted, there are a lot of tuners and dyno operators who know how to manipulate the numbers to show "results". I don't care how much more I may get on a dyno. If I can't feel it on the street or if it doesn't show up at the track, then it's just a number to brag to people about.
Old Nov 3, 2006 | 04:25 PM
dan-t's Avatar
dan-t
funny story..oh the games people play..
To dyno question
