Diff between "Comp Mode" vs. Trac Cntrl "Off"?
Old Nov 5, 2006 | 01:23 PM
blkvet6's Avatar
blkvet6
Default Diff between "Comp Mode" vs. Trac Cntrl "Off"?
What is the difference between hitting the console button ONE time (= Traction Control "Off") versus "Competitive Driving Mode" (per the owner's manual = "pressing the Active Handling button on the console TWO times within a five second time period")?
They both seem to accomplish the same thing = "allows the driver to have full control of the rear wheels" (while the Active Handling System remains ON in both cases).
So what's the difference between Traction Control "Off" vs. "Competitive Driving Mode" (one button press versus two button presses)?
Any explanation would be most appreciated!
Old Nov 5, 2006 | 01:47 PM
johnodrake's Avatar
johnodrake
Moderator
As I understand it, in the comp mode, AH is less agressive.
Old Nov 5, 2006 | 01:58 PM
blkvet6's Avatar
blkvet6
Oh, OK, makes sense. Thank you so much for the timely response!
Old Nov 5, 2006 | 04:01 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Correct, In Comp mode the system allows a wider range of yaw before AH intervenes.
Old Nov 5, 2006 | 04:03 PM
ambishop's Avatar
ambishop
Does it also change the throttle mapping?
I have wondered this, as it does seem to run a different map to me
Old Nov 6, 2006 | 11:00 AM
RDunn's Avatar
RDunn
or if you just hold the button down for about 4-7 seconds you can turn it ALL off and actually drive the car
Old Nov 6, 2006 | 11:15 AM
6 speed Sid's Avatar
6 speed Sid
Comp mode must be fairly liberal as I just did some "back road" driving and it never kicked in.
Old Nov 6, 2006 | 11:39 AM
crabman's Avatar
crabman
Comp will let you slide it fair respectable. I would be careful about turning everything completly off on a backroad flogging. It wont hold you back on comp and can save your hind end. It has mine and several others have reported the same thing. This was the design goal with the setting and it works.
Old Nov 6, 2006 | 12:29 PM
Dgatto's Avatar
Dgatto
Old Nov 7, 2006 | 02:55 PM
SS MPSTR's Avatar
SS MPSTR
After my g/f lost control of our '99 after turning off the TC, I would be very wary of turning off the TC. The competition mode allows for a lot of spirited driving, but will save your butt should you let the cat out of the bag completely.
Old Nov 7, 2006 | 03:02 PM
Ranger's Avatar
Ranger
I make my passes in Traction System Off, that's one push of the button.
Allows wheel spin, but keep aggressive AH available should the rear get loose on the launch or shifts.
TS-Off has no adverse effect on straight line acceleration.
Ranger
Old Nov 7, 2006 | 07:29 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
I agree with what you are saying about Competition Mode. However, if you turn off TC (Traction Control), AH (Active Handling) is fully engaged. So you actually have more protection then when in Competition Mode. Competition Mode allows AH in a diminished capacity, as it will help steer the vehicle by selective brake application.
TC is off while in the Competition Mode, when you manually turn off TC, and when you disengage AH completely.
Old Nov 8, 2006 | 08:23 AM
Lee6's Avatar
Lee6
huh?
now i'm more confused than ever......
Old Nov 8, 2006 | 09:07 AM
6 speed Sid
I believe he is saying " TC is off in Comp, mode. TC is off when turned off. TC is off when all is off. At least that is my take and the way I understand it. For normal "Sunday afternoon driving" I leave all on. When "out with the boys", I run in the Comp mode.
Old Nov 8, 2006 | 09:12 AM
haljensen's Avatar
haljensen
Originally Posted by Lee6
huh?
1st press and release; DIC saysTC OFF = (TC OFF, AH STILL FULL ON).
2nd press and release; DIC says COMP MODE = (TC OFF, AH REDUCED).
3rd press and HOLD; DIC says TC & AH OFF = (BOTH OFF).
There's no need to go thru the sequence above if you want to end up with TC & AH OFF; Start the car, press and hold the button until the DIC says TC & AH OFF.
Old Nov 8, 2006 | 09:40 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I don't think TC is completely off in COMP MODE. I saw a 'traction control active' or similar message on my dic coming out of a tight turn at rockingham. It wasn't the 'active handling' message that comes on if you go into a drift coming out of a turn.
Old Nov 8, 2006 | 09:46 AM
Wass's Avatar
Wass
huh?
That's because it is confusing!
Traction control (TC) from the owner's manual: "operates only if it senses that the rear wheels are spinning too much or are
beginning to lose traction. When this happens, the
system works the rear brakes and reduces engine power
(by closing the throttle and managing engine spark) to
limit wheel spin."
Active Handling (AH) from the owner's manual: "The Active Handling System is a computer controlled system that helps the driver maintain directional control of the vehicle in difficult driving conditions. This is
accomplished by selectively applying any one of the
vehicle’s brakes."
TC is always on unless you push the AH button on the console. Any time you push the AH button to change a function TC will be disengaged. If you push one time, TC is off and AH is on (fully engaged). If you push twice in 5 seconds TC is off and Competitive Mode (AH partially engaged) is on. If you push and hold down for 5 seconds TC is off and AH is off. As I said, it's confusing!
Old Nov 8, 2006 | 09:51 AM
Wass's Avatar
Wass
Maybe it isn't, but here is what the owner's manual states:
"Competitive Driving Mode allows the driver to have full control of the rear wheels while the Active Handling System helps steer the vehicle by selective brake application. The instrument cluster light will not be on. The Traction Control System will not be operating. Adjust your driving accordingly."
To Diff between "Comp Mode" vs. Trac Cntrl "Off"?
