Clutch Fluid
Old Nov 7, 2006 | 07:27 PM
MtnC-6's Avatar
MtnC-6
Default Clutch Fluid
Has anyone found a source for the Super DOT4 brake fluid for the clutch? Local dealer said they couldn't get it even though there is a GM part#
Old Nov 7, 2006 | 07:31 PM
Hoonose's Avatar
Hoonose
Googled 'Super DOT4 brake fluid':
http://autodax.com/catalog/pdetail.php?prdid=99
Old Nov 7, 2006 | 08:08 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
From prior threads, this is exactly the stuff that GM wraps its own label around and sells for the Corvette clutch. Use it with complete confidence.
Old Nov 7, 2006 | 08:23 PM
billcar9999's Avatar
billcar9999
I have 4 cans on order through www.partszoneonline.com. I paid 4.67 a can. I ordered using the part number 88958860.
I paid 8.67 through the local dealer.
Bill
Old Nov 7, 2006 | 10:19 PM
MtnC-6's Avatar
MtnC-6
Thanks appreciate the info. Just what I was looking for
Old Nov 8, 2006 | 11:21 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
I get mine from a forum vendor Fichtner Chevrolet. Place order, and it shows up at my door 2 days later.
Old Nov 8, 2006 | 11:25 AM
Miaugi's Avatar
Miaugi
Thanks!
Old Nov 8, 2006 | 03:46 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I bought mine on ebay
Old Nov 8, 2006 | 08:35 PM
hazchris's Avatar
hazchris
Default whats the difference
between " meets or exceeds DOT 4 " and super dot 4 ??? I used the meets or exceeds on mine. I got it at pep boys. is super dot 4 a marketing ploy. if a product exceeds the dot standard what more do you need? I am serious, not stiring stuff up, I just want the best fluid for the vette, thanks
Old Nov 8, 2006 | 10:18 PM
billcar9999
I don't really know the answer but my owner's manual specifies super dot 4 so that's what I got. I think the bottom line is it absorbs less water and has higher boiling points. I read this:
Since DOT 4 fluids were developed, it was recognized that borate ester based fluids offered the potential for boiling points beyond the 446F requirement, thus came the Super DOT 4 fluids - some covered by the DOT 5.1 designation - which exhibit a minimum dry boiling point of 500F (same as silicone, but different chemistry).
http://www.xs11.com/tips/maintenance/maint1.shtml
and here
http://www.castrol.com/liveassets/bp...S_RESSDOT4.PDF
Google is your friend.
cmb13's Avatar
cmb13
I can't find DOT-4 locally. Not at AutoZone, not at Sears.
Old Nov 8, 2006 | 10:19 PM
hazchris's Avatar
hazchris
beer goggle?
Old Nov 9, 2006 | 02:22 AM
Wayne88's Avatar
Wayne88
I got that 'meets or exceeds' synthetic stuff at Pep boys.
I cleaned out the reservoir about 6 times, with the 'turkey baster' and refilled it with this stuff. The clutch works fine.
Old Nov 9, 2006 | 02:48 PM
C8-Vette's Avatar
C8-Vette
Walmart has Prestone DOT 4 -12 oz can about $2.60. Its synethic and is compatiable with the factory stuff. Buy 3 cans. That what it takes to get it clear or close to clear.
To Clutch Fluid
