anyone using the trick flow heads ?
Old Nov 7, 2006 | 10:42 PM
daveven's Avatar
daveven
Default anyone using the trick flow heads ?
has anyone used the new trick flow heads ? trying to decide between the afr 205 or trick flow. afr is like a direct bolt on. trick flows you have to modify the valve covers, but they have 62c chambers for a boost in comp ratio. there supposed to flow a little better than the afr's.
