Launching a manual trans
Old Nov 9, 2006 | 08:57 PM
Dgatto's Avatar
Dgatto
Default Launching a manual trans
Just looking for a little input on exactly how you launched,,,,
When I had my c4 ZR-1 I would rev to 2100 then dump the clutch and go wot and I would hook and launch. In the C6, I go totally by the feel..... dont even look at the rpm's and come off the clutch gradually while squeezing the throttle gradually, until I feel it hook...then WOT.
Just looking for input from SUCCESSFUL manual launches, street or DR's/
Thanks........
-Dennis
Old Nov 9, 2006 | 09:08 PM
yell03's Avatar
yell03
Dennis -
I"ve used your same technique in all my cars, 2000rpm dump, as soon as I feel it hook I would go WOT.
This tecnhique had always worked for me:
1.8s in my Viper on stock tires
1.8s in my 03 Cobra on DRs
1.9s in my 03 Cobra on stock tires
I tried it in my C6 and it resulted in a 2.3 and a 2.26 60'.
Saturday I am going to give it another try, but only at 1500-1800rpms and see what happens.
My best 60' in my manual C6 was to slip the clutch and gradually feed in throttle, this resulted in a best of a 2.023 60' on stock tires.
But, I am an all or nothing type of guy, so I will try my old technique again, hopefully a lower rpm launch will get me consistent 2.0s.
Howard
Old Nov 9, 2006 | 09:29 PM
xstang's Avatar
xstang
Originally Posted by yell03
Dennis -
Howard
I can get 1.9s every time with BFG Drs by using a 3000 rpm laung with a quick clutch slip.. This was in 48 degree weather (not the best launching conditions)
Old Nov 10, 2006 | 01:25 AM
CharlesT's Avatar
CharlesT
Sorry for a noobish question here, but what EXACTLY is dumping the clutch?
Old Nov 10, 2006 | 01:34 AM
Robert@Advanced Dyno's Avatar
letting it out really fast
Old Nov 10, 2006 | 06:05 AM
yell03's Avatar
yell03
xstang -
Try 2000rpms with the BFG DRs if you don't do a long burnout.
With my Viper never cut worse than a 1.8 with a 2000rpm launch, 3000rpms got me a 1.68 60'. That was on Kumho Ecsta V700 R-compunds.
With both my 03 Cobras 2000rpms on BFG DRs got me 1.8s or 1.9s.
Upping that to 3000rpms did worse.
I think since with a manual tranny I don't do a long burnout I can't launch at higher rpms.
What really blows my mind is how well the automatic C6s launch on STOCK tires just by hammering it off idle.
1.8-1.9 60's are common with the A6s and my A4/3.15 Vert cut a 1.92 on BASE runflats (Treadwear 300)
With my manual tranny C6 on stock tires I would be spotting the automatics 3-4 car lengths and then having to finally run them down just after the 1/8th. Oh, and you don't always run them down.
Howard
Howard
Old Nov 10, 2006 | 06:15 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
one method you might try is:
(hopefully i can describe it accurately)
bring the rpms to around 1500-2000
slowly begin to release the clutch and depress the gas pedal with the same speed at which you release the clutch, uh yep you'll be slightly slipping the clutch for a moment.
at about the halfway point of clutch release drop the hammer. fully release the clutch and fully depress the gas pedal. your rpms should be around 2500-3000 at the halfway point, before you fully release the clutch and fully depress the gas.
you can also slip the clutch a tad between shifts if you want, if you do it right you can make the front of the car lift and drop. very fun when you are 'chomping' on a ricer.
Old Nov 10, 2006 | 06:21 AM
yell03's Avatar
yell03
Zig -
I tried that method my 1st time at the track with my C6 and it produced my best 60's of the day, a 2.03 and a 2.12 compared to my 2.26 and 2.30 dumping the clutch.
My buddy Jim says a trick is to say "One Chimpanzee" as you are doing that, by the end of "Zee" you should be completely off the clutch and at FULL throttle.
If my clutch dump technique does not work on my 1st runor two this week, I'll go back to that method.
Howard
Old Nov 10, 2006 | 07:04 AM
xstang's Avatar
xstang
I try to keep the car from rocking at all... I powershift (-:
Doesn't this run sound like an auto
http://s53.photobucket.com/albums/g6...ictures006.flv
Old Nov 10, 2006 | 07:17 AM
yell03's Avatar
yell03
NICE!
I can't do a standing burnout in a manual and I can't powershift either.
My left brain always makes my right foot lift
Howard
Old Nov 10, 2006 | 07:24 AM
xstang's Avatar
xstang
NICE!
Howard
I know what you mean... It took me a long time to get it down... Lucky for me, I have an empty 1/2 mile strip near my house that is always empty! Anyone can do it with practice...
I haven't perfected the burnout either (-:
Old Nov 10, 2006 | 08:18 AM
Zig's Avatar
Zig
nice, vid.
agreed, it seems like i do better when i keep the nose in the air. gotta complete that shift before the nose drops.
i was referring to being 'stuck' in 'traffic' (at the track of course). you know, when you can't really get around the guy in front of you and you need him to move out of the way, just kinda play pac-man with the front end, chomp chomp chomp. i'm chewing on your rear - get it out of the way.
Old Nov 10, 2006 | 08:19 AM
xstang's Avatar
xstang
Originally Posted by Zig
nice, vid.
That's great! I can't stand slow drivers
Old Nov 10, 2006 | 09:04 AM
Dgatto's Avatar
Dgatto
NICE ....I love to power shift too...... Will be doing it tonight!
Old Nov 10, 2006 | 09:05 AM
Dgatto's Avatar
Dgatto
Thanks again everyone, hopefully Atco wont be to crowded and I can get a lot of passes........
You will all know tomorrow!
Old Nov 10, 2006 | 09:21 AM
xstang's Avatar
xstang
I can't wait to see what you run.....
Old Nov 10, 2006 | 09:49 AM
not08crmanymore's Avatar
not08crmanymore
Default Launch
Won't the wheels just spin and spin by launching at 3 grand???I never understood how that can work??
To Launching a manual trans
Old Nov 10, 2006 | 10:10 AM
xstang's Avatar
xstang
Heated up BFG Drag radials hook no problem at 3K... Even bogs down sometimes....
Old Nov 10, 2006 | 10:34 AM
Dgatto's Avatar
Dgatto
525 RWHP.... Cant launch at 3k....whells will break loose..............even with slicks.
Old Nov 10, 2006 | 12:13 PM
Whiterock1's Avatar
Whiterock1
Fast let off, sometimes called side stepping the clutch. I've found 2500, pause for just a beat, and wot works best for me. No wheel hop, good hookup with the F1 SCs on my Z51 '06. Your results may vary...
