Top Speed For Each Gear/A6
Old Nov 11, 2006 | 11:09 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Default Top Speed For Each Gear/A6
Can anyone tell me what the top speed is for each gear in the A6.
1st?
2nd?
3rd?
4th?
5th?
6th?
Old Nov 11, 2006 | 11:12 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
This info came from a forum member.
ENGINE<------Vehicle_Speed------------>
RPM...1ST...2ND...3RD...4TH...5TH...6TH
1000....8....13.... 20....27....37.... 47
1500...12....20....31....41....55.... 70
2000...16....26....41....43....73.... 93
2500...20....33....51....68....92... 116
3000...23....40....61....81...110... 140
3500...27....46....71....95...128... 163
4000...31....53....82...109...147... 186
4500...35....60....92...122...165... 186
5000...39....66...102...136...184...186
5500...43....73...112...149...186...186
6000...47....79...122...163...186...186
6500...50....86...133...176...186...186
Old Nov 11, 2006 | 11:18 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Old Nov 12, 2006 | 12:49 AM
ilkhan's Avatar
ilkhan
This...
Nice to know you can go from 4k to 6k in one gear and not gain any speed. How exactly does that work, anyway?
http://www.geocities.com/z_design_st...ion_z28_6.html
http://www.corvetteactioncenter.com/...2006specs.html
All the info you need to get speed in gear for anything youd like.
Old Nov 12, 2006 | 02:37 AM
TMyers's Avatar
TMyers
In 6th gear about the top speed you can get is about 140mph. There is not enough torque to turn the gear any faster.
Old Nov 12, 2006 | 10:00 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I am just wondering if you were running in the 1/8,would it be better to use the paddles? The reason why i ask is that we have an 1/8 track here in Western NY.
Old Nov 12, 2006 | 10:35 AM
Vette_DD's Avatar
Vette_DD
It's called theoretical speed VS maximum actual tested speed of the vehicle.
Old Nov 12, 2006 | 02:31 PM
TMyers's Avatar
TMyers
If you can get the 1-2 gear shift right you will be faster in paddles. But it is hard to do.
To Top Speed For Each Gear/A6
