L92 heads
Old Nov 12, 2006 | 01:27 AM
medzcine's Avatar
medzcine
Cruising
Default L92 heads
These heads show much promise the guys at LS1tech.com are all over them. I'm thinking of doing an L92/L76 combo at a later date due to some business concerns presently.
Question do you guys know if the headers off of an LS2 will fit? Any and all info will be greatly appriciated, thanks ahead of time car nuts.
medzcine
Old Nov 12, 2006 | 03:51 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
medzcine
Old Nov 12, 2006 | 05:11 AM
stinky's Avatar
stinky
According to all that I've asked, YES, the are supposed to fit.
Old Nov 12, 2006 | 12:46 PM
snappy28's Avatar
snappy28
Cruise-In VIII Veteran
You may want to talk to these guys: http://www.dragonrace.com/
Old Nov 12, 2006 | 01:58 PM
SpinMonster's Avatar
SpinMonster
They are intended for a 4.065 bore so the valves may be shrouded.
Old Nov 12, 2006 | 11:20 PM
medzcine's Avatar
medzcine
Cruising
Thanks for the info.
Old Nov 12, 2006 | 11:24 PM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
Do these heads drop compression ratio?? They flow 325...what do the stock LS2 heads flow???
Thanks!
John
Old Nov 12, 2006 | 11:41 PM
medzcine's Avatar
medzcine
Cruising
The heads do drop comression some, I believe they have 72cc combustion chambers (LS2 are 67cc I believe) which would make them excellent for forced induction set ups. I plan on milling mine some and porting them especially on the exhaust side. I hope this helps.
Old Nov 13, 2006 | 01:49 AM
Brabus2's Avatar
Brabus2
L92 heads:
Intake runner = 260.6cc
Exhaust runner = 90.0cc
Chamber = 69.8cc
Old Nov 13, 2006 | 03:28 PM
tucker0298's Avatar
tucker0298
ive been following the thread on ls1tech about these heads and i know that you have to have the intake to match the heads because the stock intake wont bolt on . does anyone know if there is still a shortage of these intakes or are they readily available now?
Old Nov 13, 2006 | 11:05 PM
medzcine's Avatar
medzcine
Cruising
They are becomeing very available. There seems to always be one or two on eBay and I belief gmperformance is now presently offering them. I've inquired and have been told that all of your LS2 parts will work on the L76 intake manifold minus the fuel injectors.
Hope this helps.
To L92 heads
