Repacing Tweeters
Old Nov 12, 2006 | 05:24 PM
tloon's Avatar
tloon
Default Repacing Tweeters
Want to replace tweeters in the 07 Bose system,doors only. Does anyone know what the positive and negative colors will be?
Old Nov 12, 2006 | 08:27 PM
shurite44's Avatar
shurite44
Hi, go to the audio section and do a search for C6. There are quite a few threads about modding the system there.
Old Dec 7, 2006 | 01:17 AM
2006c6keller's Avatar
2006c6keller
I doubt you will hear the difference if connect the polarity out of phase, just make sure you connect all the replacement tweeters the same way. The db level for the new tweeters will probably not be of much different than what you have now. Try adjusting your tone control to see how much more improvement you get. Also, on the NAV system, each individual (yes EACH individual station or source) has to be set for each station. Eg. Six (6) presets, six separate equalizations. I know this is a pain. With all the ambient noise in and around the car, upgrades won't help much if any at all.
To Repacing Tweeters
