Hunt for idle issues
Old Nov 13, 2006 | 08:37 PM
Rada 1's Avatar
Rada 1
Default Hunt for idle issues
Just took the car back and had the tuner adjust it but it is not much better, is it in the tune, should they be able to adjust it out, I have been told it was an easy.
Would be grateful for any additional advise, it's about 100 miles back to my tuner.Car runs great other than this! it was fine until they installed the cam -224/228
Old Nov 13, 2006 | 09:21 PM
NORTY's Avatar
NORTY
Idle hunt? Sounds like an air/vacuum leak.
Old Nov 14, 2006 | 02:46 AM
Rada 1's Avatar
Rada 1
only happens when you come to a stop, it will hunt 2 or 3 times then idle fine at about 800 rpm,
Old Nov 14, 2006 | 05:38 AM
not08crmanymore's Avatar
not08crmanymore
You sure it's not just the character of the cam?
Old Nov 14, 2006 | 06:21 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Sounds like that's what the particular cam is going to do, no matter what you do if as you say or someone suggested that you look real close for a vacum leak.
Old Nov 14, 2006 | 10:03 AM
HITMAN99's Avatar
HITMAN99
This is not a vacuum leak, this is a tuning issue.
Old Nov 14, 2006 | 01:22 PM
SpinMonster's Avatar
SpinMonster
Increase idle air in the running airflow table from 400-1200rpm. It will steady it. I had that cam in 2 cars and other than the shake it runs fine.
Air leaks cause a raised steady idle at 1200-1400 rpm. It is because there is too much air. Hunting for idle means there isnt enough. Its gasping.
Old Nov 14, 2006 | 02:21 PM
Michrider's Avatar
Michrider
A shortcut way around it is drilling holes in the throttle blade. The professional way to correct it is in the tuning tables, needs more idle air.
The same thing used to happen on old carbureted hot rods. Put a wild cam in there and have all kinds of idle problems. I can't tell you how many Holley carbs I've seen with holes drilled in the throttle blades. Lets you get the throttle blade closed to the proper idle position in relation to all the fuel ports and still allow more air. The same trick works with FI, however it's a backyard approach. A real good tuner should be able to fix it in the tuning tables.
Old Nov 15, 2006 | 05:52 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
you could also have a loose plug wire. it would run fine above idle but at idle the intermintent spark could cause it to hunt.
To Hunt for idle issues
