DTE rear install underway
Old Nov 14, 2006 | 10:11 PM
MR Z's Avatar
0MR Z
Former Vendor
Default DTE rear install underway
Just wanted to let you guys know I have started my DTE diff and brace install today. Worked on the car for about 3 hours and have the cradle ou of the car. I will be posting up a step by step how to with pics later on this weekend. Till then here are a few pics of my ride.
Old Nov 14, 2006 | 10:13 PM
debmwb's Avatar
debmwb
Good series!!! Keep us posted...it looks great so far!
Old Nov 14, 2006 | 10:16 PM
NoRice4Me's Avatar
NoRice4Me
Please post pics of the DTE diff & brace too!
Old Nov 14, 2006 | 10:54 PM
SickRick's Avatar
SickRick
WOW!
Doing a rear on on jackstands. You have more testicular fortitude than most.
I change my friggin OIL on a lift...
Rick
Old Nov 14, 2006 | 11:47 PM
07MontRedcp's Avatar
07MontRedcp
What stage DTE are you installing? What lead you to make that choice?
BJK
Old Nov 15, 2006 | 06:41 AM
EuroRod's Avatar
EuroRod
Gee, that looks like fun.
Old Nov 15, 2006 | 09:23 AM
MR Z's Avatar
0MR Z
Former Vendor
Thats all I have. , but I'm used to it. I have done several 10-bolt to 12-bolt swaps in f-body's on the ground using jack stands.
Stage 3 with 4.10's. I went with these because I go to the dragstrip fairly often and have every intention of launching this car hard sooner or later.
Old Nov 15, 2006 | 03:08 PM
xstang's Avatar
xstang
Awesome....
Old Nov 15, 2006 | 03:26 PM
07MontRedcp
Sounds good. Are you looking into the brace and maybe a high tech carbon drive shaft. If that one breaks (drive shaft) it splinters. The OEM shaft could end up going thru the floor board according to what I've read. Could be wrong.
BJK
Old Nov 15, 2006 | 03:40 PM
MR Z's Avatar
0MR Z
Former Vendor
Yes I am doing the brace as well, but not a new drivwshaft. Maybe down the road I will look in to it.
Old Nov 15, 2006 | 06:43 PM
fullboogie
Don't know if the C5 and C6 applications are similar enough, but if so, you can find a great write up on the brace install at:
http://www.cajundude.com/differential.htm
Old Nov 15, 2006 | 06:49 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Now that is a great step by step !
Old Nov 15, 2006 | 07:19 PM
30YR W8T's Avatar
30YR W8T
Looking forward to the step by step as well. I did the brace on my car without pulling the rear cradle...never again, and will probably change the diff out in the future to something that I hope is much stronger. Good luck and please note any really difficult steps in the process.
Old Nov 15, 2006 | 07:20 PM
EuroRod's Avatar
EuroRod
Sure wish some enterprising soul had done this for a ProCharger install.
Old Nov 15, 2006 | 09:58 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Great pics. I've assisted doing this on a lift a couple of times, hats off to you for doing it on jackstands!
You might need a tune to prevent an early 2nd gear rev limiter. Please see this thread and make sure your tuner knows (if you don't buy HP Tuners and do it yourself). I'm not sure how many tuners know about this:
http://forums.corvetteforum.com/show....php?t=1525166
Old Nov 15, 2006 | 10:33 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
You are a brave soul. Your pics aptly define why I simply "write a check"
Old Nov 16, 2006 | 12:29 AM
gdawgg's Avatar
gdawgg
To DTE rear install underway
Old Nov 16, 2006 | 04:46 AM
excessive81's Avatar
excessive81
where the fun in that
Old Nov 16, 2006 | 08:02 AM
schilitj's Avatar
schilitj
Driving
Old Nov 16, 2006 | 09:58 AM
k-line's Avatar
k-line
Had the DTE stage 2 w/ 4.10 installed about a month ago. I've got a M6 Z51 and was hitting rev limiter early and had to do the fix mentioned above. Also when first driving after install upon turning there was a shaking but some figure 8's took care of it. I was told it's because the oil hasen't run through the rear and the clutch disk were dry. I also upgraded the clutch while I had everything apart. Have fun 4.10's on these cars are a real kick.
