A6 Overdrive
Old Nov 15, 2006 | 08:15 AM
10mikeymike's Avatar
10mikeymike
Default A6 Overdrive
It's my understanding that 5th & 6th gears are essentially overdrive gears on the A6. If that's the case, is there anyway to prevent the transmission from making these last 2 shifts short of using the paddles? I purposely opted for the A6 transmission and have no complaints about it at all. Despite this, I've wondered why there isn't a way to keep the transmission from shifting into overdrive while maintaining the ability to automatically shift from 1st through 4th gears. I like the A6, but would also like to ability to drive around town in 4th and not have to manually downshift or, consciously shift into 1st each time I come to a stop. With the 1-4 skip shift eliminator available for the M6, I'm surprised something like this isn't available for the A6.
10mm
Old Nov 15, 2006 | 08:35 AM
HITMAN99's Avatar
HITMAN99
Only way I know is to accomplish this would be to use the paddles to stay in 4th gear, then when you come to a stop, move the gear selector up to D, then back to S.
Old Nov 15, 2006 | 11:41 AM
AP's Avatar
AP
10mm
I dont understand why you would want to do this? It seems as if when you are just driving around town you want better milage ... i.e Overdrive...
Old Nov 15, 2006 | 11:57 AM
10mikeymike
Mileage isn't really an issue for me. On occasion, I'd like the to have the power and acceleration of 4th gear available without the need to use the paddles or manually downshift to 1st when I come to a complete stop. It would also be an option for guys with A6 automatics who want a performance exhaust and don't want to buy Corsa exhaust systems to avoid the drone you get a low speeds with the transmission in 5th or 6th gears. I know this can all be accomplished with the paddles, but it would also be nice if you had the option of using 4 or 6 gears in true automatic mode.
10mm
Old Nov 15, 2006 | 01:47 PM
shurite44's Avatar
shurite44
Nope, only way is to use paddles.
Old Nov 15, 2006 | 02:07 PM
yell03's Avatar
yell03
At least with the A4 you can just leave it in 3rd, which is almost the same as the A6s 4th, and completely avoid the OD.
I still would like to drive the A6 and try out the paddles.
Howard
Old Nov 15, 2006 | 09:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Probably the best way to deal with it is to avoid thinking about "normal gearing" vs "overdrive". Just look at the tach, if you want more rpm to keep the engine in the "sweet spot" for sudden acceleration, use paddles as necessary and don't worry about what gear number is showing. But, be prepared to burn more gas and more oil. Sometimes a LOT more.
Old Nov 15, 2006 | 10:26 PM
DSOMC6's Avatar
DSOMC6
I agree with the poster of this thread. The A6 does shift into 5th and 6th gear far to early in my opinion. At times, if I am not in paddle mode (not very often) when attempting to accelerate fast the computer chooses a gear that is far too low for the speed I'm going and the RPM's hit 5000 upon downshift! Major programming flaw in my opinion. Because of this, I seldom drive without being in paddle mode.
Old Nov 15, 2006 | 11:22 PM
Atomic-Vette's Avatar
Atomic-Vette
your other option is to have shift points reprogrammed.
Old Nov 16, 2006 | 10:18 AM
whayes's Avatar
whayes
You can use HP Tuners software to program the shift points for each gear in the A6. You could just set a high MPH shift point for 5th and 6yh gear. I did it and it works just fine.
Old Nov 16, 2006 | 10:23 AM
shurite44's Avatar
shurite44
I really don't see any problem with how it is programmed. Unless you are driving like you are in James Bond movie or something. Even then if you get on it hard it is going to downshift and not shift again until you hit the redline. Non issue really.
If you are on the track use the paddles.
To A6 Overdrive
