Fog Light Replacement - Access?
Old Nov 19, 2006 | 12:33 PM
05_C6Z51's Avatar
05_C6Z51
Default Fog Light Replacement - Access?
Where is the access panel to relace the fog lights?
Old Nov 19, 2006 | 02:16 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
IMHO it is easiest to pull the plastic fender well covers off. Turn the wheel to one side or the other to get easier access.
Good luck
Old Nov 19, 2006 | 07:57 PM
05_C6Z51's Avatar
05_C6Z51
Good luck
Thank you.
Old Nov 19, 2006 | 08:33 PM
LEAVINU's Avatar
LEAVINU
just did mine last week and I jacked one side up pretty high- I cut my bushings so car sits very low. There are two 7mm screws on the underside holding the front part of the plastic. Remove those and then push back and you will see tabs on the front end of the fender wheel that slide into the bumper. Once that is all out of the way reach your hand in there and twist. All done.
Still cant understand why we just cant get nice clean looking bulbs from the factory.
Old Nov 20, 2006 | 03:53 PM
05_C6Z51's Avatar
05_C6Z51
Thanks, I'll give it a shot tonight.
To Fog Light Replacement - Access?
