Base Dyno A6
Old Nov 20, 2006 | 07:37 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
Default Base Dyno A6
Just had a base line dyno this past weekend and was wondering how my numbers compare with others???? 348 rwhp 352 torque. Only mod is a Vararam but with no ram air???? Just curious. Thanks
06 A6
Old Nov 20, 2006 | 07:55 AM
BlackZ51Vett's Avatar
BlackZ51Vett
I think that is generally in-line with others. With the VaraRam you'll pick up some ponies at speed.
Fore58's Avatar
Fore58
Very good numbers, especially the torque.
Old Nov 20, 2006 | 08:37 AM
I1uluz's Avatar
I1uluz
What type of dyno? Are those SAE corrected or Actual numbers? What gear were the pulls done in?
IMO they seem kind of high for a stock setup.
Old Nov 20, 2006 | 08:51 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
SAE, 4th (A6)
Old Nov 20, 2006 | 10:12 AM
AP's Avatar
AP
Great Numbers ...
Old Nov 20, 2006 | 10:33 AM
glennhl's Avatar
glennhl
By far the best numbers I've ever seen for an A6. Mine made 334 rwhp and most have been in line with that.
Old Nov 20, 2006 | 10:42 AM
HITMAN99's Avatar
HITMAN99
My guess is that these numbers are from a Dynojet. Mustang dyno's are typically about 10-12 HP lower.
Old Nov 20, 2006 | 11:15 AM
TMyers's Avatar
TMyers
I agree, those are some big numbers. With a tune and Vararam I only have 350 something for both torque and HP.
Old Nov 20, 2006 | 12:09 PM
I1uluz's Avatar
I1uluz
Originally Posted by bassvet
SAE, 4th (A6)
DynoJet or some other type like a Dyno Dynamics dyno?
My baseline 07 A6 pulls done in 4th were 337.1 - 342.5 then after Honker, CC 1.85 rockers and tune 364.1hp - 360.9tq.
I know here in Norfolk Va this weekend I was helping a friend tune 3 C6's, 1 C5, a Calloway 383 Imp SS and 1 Fbody on a DynoJet 248. Actual readings were about 20hp higher than when the SAE correction factor was used. That is why I asked if they were corrected or not.
Old Nov 20, 2006 | 01:12 PM
SoldSyclone's Avatar
SoldSyclone
Thants the strongest A6 I have seen 320-330 is normal.
Old Nov 20, 2006 | 01:24 PM
Waveblaster785's Avatar
Waveblaster785
Dyno Dynamics would read similar to a mustang dyno. They are load bearing.
Old Nov 20, 2006 | 04:02 PM
I1uluz's Avatar
I1uluz
Depends on how the Dyno Dynamics dyno is setup. We have one locally that is setup to read like a DynoJet. I had my LT1 6spd RX7 on it and a DynoJet 224 back to back for dyno testing. Dyno Dynamics it put down 346/330 DynoJet was 345.52/329.72 SAE corrected on both. A 224xLC DynoJet is a eddy current dyno also where a 248 isn't.
Old Nov 20, 2006 | 04:45 PM
C6Rluvur's Avatar
C6Rluvur
Exactly! I've seen 315-335 as the norm for A6's, either that guy has a factory freak maybe the original poster could post a pic' of the actual dyno in question thanks
Old Nov 21, 2006 | 01:52 AM
LS1LT1's Avatar
LS1LT1
Old Nov 21, 2006 | 07:47 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
I'll post the graph this afternoon don't have it at work
Old Nov 27, 2006 | 08:22 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
who wanted to see the graph???? see post 16
To Base Dyno A6
Old Nov 27, 2006 | 12:16 PM
C6Rluvur's Avatar
C6Rluvur
06 A6
Looks like you lowered re-edited you #'s quite a bit what happened? your original post was in the 360's for both hp & to as I recall
Old Nov 27, 2006 | 12:42 PM
bassvet's Avatar
bassvet
St. Jude Donor '10
edited only the torque original post was misread as 362 instead of 352
Old Nov 27, 2006 | 05:48 PM
NORTY's Avatar
NORTY
06 A6
Did you have a "baseline" pull done? Good #'s with the mod,but it isn't a baseline since it isn't stock.
