Pressure sensors for Z-51
I need to buy 2 sensors for my 06'. Is there any difference where I buy them?? New? Used? Any difference between 05 and 06?
I know I saw a post about them , but couldn't find it.
-Dennis
-Dennis
-Dennis
-Dennis
http://forums.corvetteforum.com/show...0&postcount=10
The batteries in the sensors have a "design life" of 10 years, but I'm not counting on mine lasting past 7 or so - when I'm getting new tires about then I'll get new sensors.
No C6 sensors are older than about 2 years right now, so maybe some used ones might be okay. In several years you're not gonna know how old a used sensor is or how much battery life is remaining.
Bob
Originally Posted by beezeye
Click on the link below to see a post about getting them from Fred Beans:
Bob
Bob
-Dennis
-Dennis
Parts Bob or Parts Tom at Fichtner can help you with this.
I can give you the part # for the UJ9 but I don't have it at work. If you need the number answer this post and when I get home I will get it for you.
Bob
Dennis, the post by " beezeye " has a link which shows the following part number:
25758220 This is the number that matches RPO UJ9 which you will find in your glovebox. It is most probably the one you need. I couldn't find the other code and this one is the most common.
Bob
Originally Posted by fat bob
Dennis, there are two types of sensors for the C-6. I think the most common is under the code UJ9. The type you need for your car can be found by checking the codes in your glovebox or giving a dealer your VIN number and they will tell you what type you need.
Bob
Bob
-Dennis
Thanks Bob...definitly!
-Dennis
-Dennis
Bob
