Hallteck cold air induction kit to go with my stinger?
Banned Scam/Spammer
I still have the stinger in the box? (not yet installed)
Is the new Halltech cold air induction kit a worthy addition as well?
Should I go for both, neither or just stinger?
What can I expect in hp with both?
Is this stuff wothwhile or just a hoax?
We data logged my car and then CBRF's car. CBRF had the Halltech cold air mod and the inlet air temps to the engine were almost 20 degrees cooler! However, he did not buy the shroud from Halltech, he pulled out his and modified it the same as the Halltech. He even put in the screens.
save your money, either way you have to pull that piece out, just mod the one that you have, or if you don't have the time just drill some holes in the area, it is easy 5 minutes job.
Former Vendor
You are right Mr.CBRf, one can simply cut a hole(s) on the shroud and turn over your filters for filtration and call it a day. However, it does not work quite the same as a true ram air set up and this is why:
The cavity found in front of the radiator/shroud area is a high pressure area that gets plenty of air once a C6 rolls down the road. The Air-Charger, Vararam, BPP and Callaway cai kits all provide a format for your Vette to suck in more air and thus produce more power.
Of all the CAI kits for the C6 Corvette out there, the Air-Charger and the Vararam are the only two that gives its owner the opportunity to suck incoming air and not the hot air that floats from around the radiator cavity.
The thing about the Air-Charger is that it sits higher on the vehicle (right below the bumper frame behind the grill mesh). while the Vararam sits lower and thus increasing the chance of water ingestion. All of the CAI kits are great quality units, and they all they WORK! The biggest question is, which one gives you the biggest bang for the bucks? And which one is the easiest to install?
Check out: Halltech web site, Vette Doctor Website and 21st Century musclecars site for product information. Many C6 Corvettes owner have seen great results by combining the Air-Charger and the Halltech Stinger filter with out breaking thier pockets. The Z06 owners have seem similar success when combining the Air-Charger and the F1 Halltech filter although further testing are now being conducted on this particular (Z06) combo.
Just food for thought.
the original poster wasn't referring to the halltech air charger, he was asking about the halltech cai (i think since he say cold air induction, instead of air charger) i was simply posting if one were to cut the piece on each side of the front grill area, you can get ambient air into the engine compartment...this air isn't by the radiator, if someone doesn't mind cutting the shroud, then by all mean. if would be interesting to see a picture of halltech air charger on a car.
Former Vendor
If you want to see a picture or how it is installed, please visit the vette doctors website. It was installed on a C6 Z06, but it's the same procedure for the standard C6 Corvette.
The Halltech filter goes well with this CAI kit because it sits right on top of the opening and air shoots straight into the nice Stinger filtration filter.
Thanks.
Banned Scam/Spammer
Originally Posted by Myhardtop
Sorry brotha, if I came a little off base
Thanks.
Thanks.
ttt
Former Vendor
can you kindly provide a link? i couldn't find it on that website. thanks
Also visit: http://www.corvettec5.com/store
Hope this helps
Thanks.
Sure. Here it is: http://www.thevettedoctors.com/ and goto: http://www.thevettedoctors.com/airchargerinstall.shtml
Hope this helps
Thanks.
Hope this helps
Thanks.
CBRF, why don't you come by and drop my shroud for me either Monday or Tuesday after work so I can see how much of a change it is this Friday night.
Also, bring by your plexiglas deflectors, you don't need them any more.
Former Vendor
thank you, i went to www.vettedoctor.com, that was my problem. i like this air charger, the shroud is still seal off after the cut.
i can swing by tuesday after you get off work, but i still need my plexiglass deflectors, since the air ducts doesn't cover up the entire holes on both sides. maybe we can data log your car before and after at the same time. let me know.
St. Jude Donor '09
Thanks.
Thanks.
Former Vendor
How do you remove the grill? I really like the Air Charger. I just hate to pay $300 for a piece of plastic worth about $50.
It's easy, only 10 plastic push in clips holds it place. However, many guys don't even bother with that, they just snake from under the bumper. Be on the look out for a special pricing
Former Vendor
Folks, allow me to further explain myself. I started the Air-Charger CAI kit about a year ago, and, like you, I am an enthusiast who wanted more out of my investment. I purchased a 2006 Z06, and shortly after, I realized that this potent little mill needed some additional method for breathing thus; the Air-Charger was created.
I and two other individuals invested plenty of time and money (mainly me) to make this CAI kit possible for the public. Shortly after we all realized the cost of doing a venture like this, my partners decided to give up the pursuit of this business endeavor and that is how I assumed total ownership and risk. As of now, my wife and I are the sole owners of Air-Charger.
I met and talked to many C6 owners and realized that the standard C6 was even more restrictive than the new Z06! We tested the Air-Charger with different air filtrations and found that the Halltech Stinger was the hottest ticket. My very first C6 customer, Alex (Silver C6 seen on Pinks All Out), was kind enough to allow us to test and test over a period of three months; our efforts netted some outstanding results. In fact, please feel free to contact LG Motorsports where Alex does most of his automotive business and dyno testing. They can attest that his Vette is one of the highest dynoing and hardest running A4’s they have ever seen!
Now, I am not going to tell you that the Air-Charger is the highest, most powerful CAI kit out there; I think all CAI kits for the C6 and Z06 are a great addition to improve performance. I feel very fortunate to at least have a chance to be a player in this very tough market. I CAN tell you guys that most of the fastest C6 Z06’s and standard C6’s are sporting the Air-Charger, Halltech filters and/or a combination of both…just look or ask around…is this a coincidence? Who knows?
If you are interested, the Air-Charger can be purchased through Halltech Systems, 21st Century Musclecars, and The Vette Doctors. I am currently working on a few other forum vendors for greater and faster distribution.
If you would like more information, please check out the December 2006 issue of “Vette Magazine” and the September 2006 issue of “Corvette Magazine”. Both publications tested the Air-Charger with positive results. Further publications are currently in the works!
Also, be on the lookout for an upcoming Christmas special. The pricing will be HARD to beat…I promise!!
Thanks,
Carlos
Thanks,
Carlos
