Squeaky Clutch Pedal...
Old Nov 23, 2006 | 02:01 AM
pimpyellowtt's Avatar
pimpyellowtt
Default Squeaky Clutch Pedal...
Just recently my clutch pedal has begun to squeak . It sounds like a spring like squeak, and it only happens upon the first 1/4 of depressing the clutch...is this something that can be lubed? Or is this something more like a throwout bearing? I have recently been doing the ranger clutch fluid changes, hopefully that has nothing to do with it, been using the stuff he recommended and uses. Anyways, any ideas guys? Thanks
Old Nov 23, 2006 | 11:46 PM
pimpyellowtt
ttt
Old Nov 24, 2006 | 06:28 PM
mfinocc's Avatar
mfinocc
Try a little white lithum grease. That should take care of the squeak and not drip out all over the place.
Old Jan 16, 2007 | 10:11 AM
vredvet's Avatar
vredvet
Be careful of the lubricants you use inside the car. You may never get the smell out.
Old Jan 16, 2007 | 05:26 PM
06C6Z's Avatar
06C6Z
Lazy? WD-40 works well. Wipe from pedals throughly.
To Squeaky Clutch Pedal...
