Clutch fluid
Old Nov 25, 2006 | 06:42 PM
MtnC-6's Avatar
MtnC-6
Default Clutch fluid
Anyone know the capacity of the clutch hydraulic system to refill after draining? It's a Z-51 if that makes a difference.
Old Nov 25, 2006 | 08:02 PM
carboman's Avatar
carboman
Doesn't matter, you can't drain it without removing the torque tube. Just suck our everything you can from above and refill.
Old Nov 25, 2006 | 08:10 PM
Jim_H's Avatar
Jim_H
Does anyone make a bleeder valve for the C6 Clutch?
Old Nov 25, 2006 | 08:36 PM
Brett Hunter's Avatar
Brett Hunter
L.A.P.D. is working on one but it has been a while since we have heard an update. Forum member SickRick had one custom built for his.
Old Jan 10, 2007 | 12:05 PM
GOOG's C6's Avatar
GOOG's C6
Fellow members, What would cause clutch fluid to leak and where would it be coming from. I have a yellowish color fluid the size of a quarter on my garage floor. Could this be access fluid from the factory and it has a drain tube? Please advise
To Clutch fluid
