C6 Automatic Transmissions
Old Nov 28, 2006 | 05:27 AM
hiznhrz's Avatar
hiznhrz
Default C6 Automatic Transmissions
I'm at the point where I want to change my 2005 A4 automatic transmission fluid. I've searched the forum and found little concerning the best fluid. I'd like to go synthetic. So far, the choices mentioned in previous posts are:
- "Redline" (complete product name not provided)
- "Mobil 1 SuperSyn Synthetic ATF Dexron/Mercon Approved for H".
- "AMSOil ATF. AMSOil doesn't list the fact that it meets the H-Spec but AMSOil has verified that it exceeds this spec".
- "RP MaxATF. A fully synthetic atf meeting the GM Dexron IIIH specs and will maintain your warranty".
Is anyone using any of these fluids? If so, any words of wisdom?
Thanks.
Old Nov 28, 2006 | 07:46 AM
HITMAN99's Avatar
HITMAN99
Try PMing PATMAN. He's the lube dude.
Old Nov 28, 2006 | 08:28 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Old Nov 28, 2006 | 08:33 AM
Buffy's Avatar
Buffy
I've use the Mobil 1 ATF; no problems with it.
What about Dexron VI? GM claims its better than IIIH all around and as I understand is compatible with pre-2006 transmissions.
To C6 Automatic Transmissions
