"Big Brake" Technical Question ???
Dec 1, 2006 | 03:55 PM
If all other parameters are correct (ie rim offset, wheels, quarters)...will the 06 Z06 Brakes be compatible with Baer Eradispeed + 1 rotors front & rear?
Experts, please step on up and thanks in advance.
Dec 1, 2006 | 08:26 PM
I would assume that if the Eradispeed rotors are Z06 specific, then they'd fit with zero issues. But why not use the Z06 rotors?
Dec 1, 2006 | 09:59 PM
Thanks for the reply Euro...the thought behind keeping the Baer are twofold: a. great rotors, b. I can purchase just the Z06 calipers and pads at a $$ savings.
Dec 2, 2006 | 08:04 AM
Have to use Z06 rotors with Z06 pads.
I tried it, and Baer confirmed it.
Dec 2, 2006 | 10:32 AM
Thanks timd38.
Dec 2, 2006 | 01:04 PM
Why couldn't you use a Z06 replacement rotor? Huge weight savings could be netted assuming there are some available.
Dec 2, 2006 | 01:22 PM
St. Jude Donor '06-'07-'08,'12-'13
Quote:
The only one that makes c6 z06 rotors right now is Stoptech
Dec 2, 2006 | 01:54 PM
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Looks like these guys make a 2 piece Z06 replacement rotor.
http://www.racingbrake.com/Two_piece...p/2072-311.htm
I believe that Hardbar also makes a very nice Z06 rotor.
Dec 2, 2006 | 03:59 PM
The problem I had was that I already has the non Z06 Baer rotors, so I didn't want to spend money for more rotors.
I hate the OE rotors because they rust.
Dec 2, 2006 | 05:13 PM
Ah, that is a bit of a hitch.
