Anyone know where the fuel filter might be on my 05/C6?
I've notice, in the last 2 days, about 1/2 second of pinging when stabbing the gas around 3000-3500 rpm......I'm thinking it might be a dirty fuel filter....
I beleive it is "inside" the fuel tank! Chevy says they don't need changing which is a bunch of BS.
I've always been a firm believer in changing fuel filters at the most every 20k-25k miles on other cars but the C6 doesn't allow for it without minor surgery. I'm assuming that it's a really good (and big?) filter to not need replacing after all those miles/years but I guess if one ALWAYS uses quality fuels and NEVER runs out of fuel or even runs it too low then it should be ok.
The only way this could happen is if the filter was so restricted that the car was running really lean. My guess is you got some fuel that just sucks. Get some premium from a different place and see if it goes away. I would think that a filter clogged so bad that it causes a lean condition would trip a code or something. Just my opinion.
All it takes is just 1 bad tank of gas.
My guess is that they make them differently than the old fuel filters.
The fuel filter on GM gasoline vehicles has not been a "service" part for years. Check your maintenance schedule. The fuel pumps at major brand gasoline fuel stations (I recommend a Top Tier fuel supplier) have filters on the gasoline pumps. Therefore, the fuel tank should only receive clean gasoline, and the in tank fuel filter will not require servicing.
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Originally Posted by cbrf4i1
they are not magical....more like wishful thinking / marketing by chevy...
If anything I would think the opposit....... I can see it now, I go in for an oil change and the service advisor says "Well we suggest you replace a few things. You reached 10,000 miles and the fuel filter is strongly suggested. The filter is $8.95 but its located in the gas tank and will cost $470 in labor.....................plus tax"
Is that whats under those padded cylinders right below the nozzle? I always wondered what that was for.
there is now a fine mesh screen in the filler tube to catch large debris before it enters the fuel tank and the filter in the pump is a very high capacity filter which can easly last a "lifetime of normal use"
but if it does need a new one it will be covered under warranty....
as an emission component...
if not covered by that your dealer can always goodwill the repair..
unless you are a di*k..
GM is trying to help the dealers by creating another golden egg to get the dealers profits up by putting the filter in the tank, it seems GM does not want "do it your selfers" to maintain there own cars. Another eg., the transmission on the C6 A6 has to be put on a rack and a probe has to be inserted to check the fluid level. GM is too cheap to put in a plate cover in the trunk and a dip stick like the oil dip stick under the hood. Pretty soon they won't let us pull the hood latch and will remove the valve stems from the tires. Just joking, but we are going in that direction!
Yep, that's it, When I first got my car, the sender unit was bad on it, and they just replaced the whole pump unit, pump, filter, and sender board, which is attached to the pump assembly. I saw all the parts, and the gas filler tube is a large flexable tube, that has a 1/3rd ratchet attachment that can be popped off, with a fine screen in it to catch anything that might accidently be dropped into the fuel line, so it can be cleaned easily by the dealership. I was also looking when I hit 30,000 miles to replace my fuel filter and was told by my service writer, that the filter was not a servicable item, and had a service life of 250,000 miles when used with good gasoline.
I agree...He may have gotten a bad tank of gas only because it's octane challenged.
