Without getting too much into theories, An X-pipe creates a scavenging effect as the exhaust pulses from the left and right banks. This scavenging effect helps draw exhaust gases from the exhaust port and through the header primaries more efficiently while smoothing the pulses as they're blended in the X-pipe. Though all exhaust manufacturers provide some form of X-pipe in their systems, they are not created equal. On most vehicles the chassis dictates where placement of the X-pipe should be made, I firmly believe the further forward, the better the signal, the better the performance. This especially is important when cats are used that will muffle the signal.
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Dont yell but what exactly is an X pipe? Im guessing it eliminates the cat. converters by replaceing them...........
Maybe to explain what an X-pipe is in addition to what it does, we should back up a little. The X-pipe is located behind the cats (if you have any). It connects the two tailpipes together for a short length and then separates again. If you think about how two round pipes might meet (not cross) to form sort of an elongated "X", you're on the right track. Where the pipes butt up together, you end up with a cutout common oval maybe 4-5" long and about 2" wide that is very carefully welded together. This interface provides the scavenging described above.
Factory pipes use an H-pipe that mate the two together. A short piece of extra pipe forms the center section of the "H".
This X-Pipe vs. H pipe is a very interesting debate. Toyota trucks dominated the Craftsman Trucks series in 2006 and they use an H pipe.
All that TRD money and still using a H pipe...Hmmmm.
Maybe they have some data?
