Flat Tire Warning
Old Dec 7, 2006 | 06:30 PM
BearCreekC6's Avatar
BearCreekC6
Default Flat Tire Warning
It's happened twice now. Accelerating onto the freeway, I get the bells and the warning that my right front tire is flat and I need to reduce speed. After about 30 seconds, the alarm clears. I happened to be on my way to the dealer for an oil change and had them investigate. They confirmed tire pressure was normal and nothing showed up on codes. Anyone experienced this and maybe a solution?
Old Dec 7, 2006 | 06:36 PM
UDRIVESLOW's Avatar
UDRIVESLOW
IVE HAD THE SAME THING HAPPEN..
MANY TIMES..
IF THE TIRE PRESSURE IS AT 24PSI COLD...
IT HAPPENS
IT ACTUALLY HAPPENED WHEN I SHOT A VIDEO..
AT 180MPH.....
http://www.youtube.com/watch?v=txs85GrqMbs
ADJUST YOUR (COLD) TIRE PRESSURE...
IF THAT DOESNT HELP THE TIRE PRESSURE SENSOR MAY NEED TO BE REPLACED..
UDRIVESLOW
Old Dec 7, 2006 | 06:40 PM
BearCreekC6
My cold pressure is 31.....
Old Dec 7, 2006 | 07:30 PM
hodgeee's Avatar
hodgeee
My dads Caddy did that all the time! At discount when they pulled the tire off to replace my worn one, they removed the sensor and took off the cover for the battery. The metal tab that the positive side of the battery touched, had some kind of rust or something on it. The guy cleaned it with an eraser, put the cover back on and reinstalled it. It must have gotten some moisture in it at some point or another. So when I would accelerate hard sometimes the connection would get lost, and the low tire pressure light would come on. This might be your same problem. I think that the ones on our cars are sealed though, so you might need to just buy a new sensor or have them replace it on warrenty. Tell them since they can't find a problem to just replace it, cause they are $65 a piece and you shouldn't have to spend your money for it.
Old Dec 7, 2006 | 07:33 PM
BearCreekC6
Thanx. If it happens again, I'll have them replace it............
Old Dec 7, 2006 | 07:41 PM
cbrf4i1's Avatar
cbrf4i1
yes, happen to me one time, one second it was fine, next sec it is showing 9psi....45 seconds later....showing 33 psi again...got the warning message like you did too.
To Flat Tire Warning
