extended oil change interval
In answer to the original posters question, if you change your oil past the oil life monitor (OLM) recommendation you are exceeding GM's recommendations (keep in mind that the service manual requires oil changes as recommended by the OLM or annually, whichever comes first). However, AMSOIL does have its own warranty. If you are going to exceed GMs recommendations, please familiarize yourself with the AMSOIL warranty requirements. And FYI, the Series 2000 0w30 is recommended for 35,000 miles or one year in normal service, or 17,500 miles or 1 year in severe service. AMSOIL consider's the following to be "severe" service:
"(4) Turbo/supercharged vehicles, commercial or fleet vehicles, extensive engine idling, first and subsequent use of AMSOIL in vehicles with over 100,000 miles, daily short trip driving less than 10 miles (16 km), frequent towing, plowing, hauling or dusty condition driving."
AMSOIL Corporate Warranty
Also keep in mind your oil filter. Though most high quality filters can be used per the OLM or 1 year, whichever occurs first, if you are going to exceed that, you'll need a better filter. The AMSOIL Ea Oil Filter is rated for 25,000 miles or 1 year of use.
C6 part numbers:
05-06: EAO32
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
You should be fine.
If you're really worried, reset your oil life monitor every 10K miles.
Who'll ever know?
I use Amsoil 0W-30 with their filter as well.
