Kooks Headers Question
Old Dec 14, 2006 | 07:46 PM
steve286's Avatar
steve286
Default Kooks Headers Question
I have a 06 with manual tranny and was wondering what were the best bang for the buck performace gains. I have seen Kooks header offered on ebay with catalytic converters for about $1500.Is this a good deal? I was also wondering if anyone with headers has had problems with them leaking after putting them on? Do they void the factory warranty?
Old Dec 14, 2006 | 10:05 PM
cudadude's Avatar
cudadude
I installed the Kooks with their high flow cats and x-pipe about six months ago. No major install problems but you have to muscle things a bit. I retained the stock mufflers and have a fairly significant drone between 1550 and 1750 RPM - doesn't seem so bad now (I think I've either gotten used to it or I don't shift into a gear that will result in that RPM range). Don't know officially about the warranty issue (this concerned me as well) - asked several people and dealerships in my town. Some said it wouldn't be a problem yet others were more reserved. I think the bottom line is that the dealer has to "prove" that whatever is wrong is a direct result of the headers being on the car. I've had no leaks. I paid about the price you quoted. I did have them Jet Hot coated and am very happy I did that. Not so sure the underhood temps are much lower (didn't do any measurments) but they look good and will not change colors over time. There is a good install tutorial at http://www.corvettemagazine.com/2005...kooks-lead.asp you might wish to peruse. HTH
Old Dec 15, 2006 | 01:16 AM
TTRotary's Avatar
TTRotary
Super happy with my Kooks LT (with HF cats) and stock cat-back. I am surprised to hear of drone, I have absolutely none (M6 car). Just nice quiet cruise and beautiful racing engine sounds at WOT. Sounds like a NASCAR race motor going through the gears.
I got mine brand new for $1350. You have to work the vendors a bit. Check Texas Speed, Tbyrne, or LAPD. They'll hook you up with a good price.
Old Dec 15, 2006 | 07:40 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I have the kooks 1 7/8 and they are great !
Old Dec 15, 2006 | 12:34 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Kooks and bullets. Paid around the same and coated them for $250. My combo too loud for some, but I love them. Warranty issues... I hope not.
Old Dec 17, 2006 | 10:08 AM
steve286's Avatar
steve286
did that price include all the O2 extanders and everything needed to complete the install?
Old Dec 17, 2006 | 10:22 AM
burtonbl103
Mine came with the 02sensor extenders !
Old Dec 17, 2006 | 01:18 PM
kermooni's Avatar
kermooni
IMHO, Consider adding the Corsa Sports. They are designed to work with Kooks, have no drone, and a lot more HP.
Old Dec 17, 2006 | 02:24 PM
bunk22's Avatar
bunk22
I've got Kooks 1 3/4" headers, x-pipe with cats and Corsa sports. Wicked sound at WOT and great power gains.
Old Dec 18, 2006 | 10:57 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I also have the Kooks 1 3/4" LT headers and the Corsa Sport exhaust. A great sound and no drone.
Old Dec 20, 2006 | 08:06 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old Dec 20, 2006 | 08:34 PM
sditch's Avatar
sditch
I have the Kooks 1 3/4" with Highflow cats with stock cat back. Had them coated by Swain Tech and they are outstanding bolt-on.
Picked up 30RWHP and about .3 ET on the 1/4 mile. You will hear alittle more valuetrain noise but it is not bad at all.
Good luck
Old Dec 20, 2006 | 08:49 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Nice gain"
Good luck
Old Dec 20, 2006 | 09:32 PM
billywallstreet73's Avatar
billywallstreet73
30rwhp is alot to pick up with just headers.Was that on the same dyno? I gained 18rwhp from my kooks.They are to loud with the off road x and bullet exhaust,but thats the way I like it.It almost sounds like it has a small cam in it with this setup. The headers are nice,but for the same price I would buy 410s without thinking twice.Your car will feel like its picked up 50rwhp.
Old Dec 20, 2006 | 10:06 PM
chemten's Avatar
chemten
Good luck
this is similar to what i want to do next. headers and keep the stock axle-back system. no modifications when you attached them to the stock rear?
Old Dec 20, 2006 | 10:44 PM
crabman's Avatar
crabman
With the 1 7/8 ARH units I ended up at 374 (I think, cant find the sheet but thats pretty close) after tune. The headers did not add nearly the sotp that gears did. Having done both separately I would absolutely without question do the gears first. I have the corsa's and if I work it just right I can get a slight drone while decelerating slowly off the brakes at around 1400 rpm. You almost have to try and do it to get it to do it but its there.
Old Dec 21, 2006 | 08:35 AM
Bone Daddy's Avatar
Bone Daddy
Member: Jr Geezer's Club
WTF? I have never heard anyone report anything NEAR a drone with stock cans behind LT's (???)
On another note....do the Kooks (or any brand) limit access to the oil pan drain plug or filter?
Old Dec 21, 2006 | 08:57 AM
I1uluz's Avatar
I1uluz
I believe what you are hearing is the exhaust gases hitting the thinner primary tube of the header. Much like a blown out exhaust manifold gasket will sound like a "TICK" vice hearing more rocker arm noise.
Old Dec 22, 2006 | 10:48 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
No problem with the Dynatech headers I had on the M6. Fixing to buy a set for the A6
To Kooks Headers Question
