Vibrating Bose Speakers
Old Dec 15, 2006 | 09:08 AM
carmichaelw
Guest
Posts: n/a
Default Vibrating Bose Speakers
On my 2005 C6 Coupe, I'm expierencing speaker vibration in my front door while playing the CD player. It only vbriates in the passenger door and not all the time.
Anyone expierence a similar problem? What was your remedy?
Suite C6
Old Dec 15, 2006 | 10:54 AM
LS WON's Avatar
LS WON
Turn down the bass or adjust the settings. In my 05 the speakers don't have "BOSE" across them so I don't have the BOSE stereo system with the CD stacker mine is the single loader.
Old Dec 15, 2006 | 02:11 PM
dbradley's Avatar
dbradley
My driver's door was making noise. Removed and found loose plastic panel. RTV solved the problem. No more rattle.
Old Dec 15, 2006 | 03:54 PM
DSOMC6's Avatar
DSOMC6
It's pretty bad with the bass up and volume cranked.
Replace speakers (and head unit for that matter)if you really want better sound.
Old Dec 15, 2006 | 04:12 PM
LS WON's Avatar
LS WON
I have my settings on MAX for bass, treble and Midrange. I did have head unit replaced with re-conditioned unit and it sounds alot better as far as reception on FM goes because before with the original headunit it was
To Vibrating Bose Speakers
