i have 2005 c6 coup. z51 with automatic transmission, 4000 miles
everytime when i slow down to turn into a driveway , and i allmost stop on the driveway on a angle, then when i apply the gas the transmission will slip like i am in neutral , then it will click into gear after a few sec , it seems to only happen when i am on a angle of a driveway,
my car is lowered i was woundering if that would cause it , are is my trans sliping , anyone experiance this ,
Have you checked your fluid level? Just a thought.
yeah fluid level sounds like a good first start especially since you say it seems to happen on angle or when slowing down which would cause fluid to slosh or flow to the other side of the pan..
i went to check the fluid , and there is no dip stick on the automatic trans. that was a first for me , the book says you only need to take it in for service if there oil leaking , which there is no leak, kinda dumb i think , i know if i take it in there going to say nothing is wrong ,
