how do you remove radio surround
Old Dec 21, 2006 | 04:14 PM
24HRC5's Avatar
24HRC5
Default how do you remove radio surround
quick question - where are the screws to remove the radio surround - I think there are 4
Old Dec 21, 2006 | 04:55 PM
mfinocc's Avatar
mfinocc
Pull off parking brake boot. Pull straight up (snaps in). Remove the (2) 7mm hex head screws located under it.
Open your center console. Pull up on the fasten seat belt light display module (snaps in). This is right in from of your console door behind your shifter & cup holder. Remove the (2) 7mm hex head screws located under it.
Pull up on the entire frame from the back first (front snaps in). Make sure to unplug all wires to cigarette lighters, traction control switch, hazard lights, etc.
You must remove all 7mm hex head screws located at radio and climate control unit. Radio will pull right out.
Old Dec 21, 2006 | 05:04 PM
cmb13's Avatar
cmb13
Agree with above. Need a lot of patience.
Old Dec 21, 2006 | 05:33 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Here are a couple good write ups:
http://forums.corvetteforum.com/show....php?t=1518095
http://forums.corvetteforum.com/show....php?t=1490531
To how do you remove radio surround
