Cool Thread on L-76 Intake Production
Old Dec 21, 2006 | 09:31 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Default Cool Thread on L-76 Intake Production
Interesting thread about how the intakes are made by a guy who does it for a living - here in the good old USA, Kentucky no less!
http://ls1tech.com/forums/showthread.php?t=627174
Old Dec 21, 2006 | 10:43 PM
LS1LT1's Avatar
LS1LT1
Very cool, people have going through big efforts importing them from Australia and low and behold they're made proudly right here in the U.S.
Old Dec 21, 2006 | 11:01 PM
martinblank's Avatar
martinblank
Default Great 411
Thanks for the find.
Old Dec 21, 2006 | 11:30 PM
NineBall's Avatar
NineBall
cool website lol
Old Dec 22, 2006 | 03:26 AM
Invisiguard's Avatar
Invisiguard
good stuff!
so these are better than our stock manifolds Im guessing?(noob)
Old Dec 22, 2006 | 03:57 AM
LS1LT1's Avatar
LS1LT1
Yes they do appear to be but unfortunately this manifold is not a mere bolt on replacement for the LS2 intake, they will only fit the later 6.2L heads.
Old Dec 22, 2006 | 05:28 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes you need the L92 heads too. I'm scoping a set of these heads over on the other board ported by Texas Speed, flowing 351 @ .600 for about $1,750 including dual springs & rockers, plus about $500 for the intake including new throttle body and injectors. Interested to see how these perform in the real world. Those are some big numbers for a low price.
Old Dec 22, 2006 | 02:56 PM
mikesul's Avatar
mikesul
Nice thread, Joe. BTW, received my L92/L76 parts today. Now to get work done on them before installation.
Old Dec 22, 2006 | 03:36 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Thanks, it's cool how they are made isn't it.
I either read on LS1Tech or someone here told me that Barry at Airflo Research here in town is very good. Might want to do a search over there.
Old Dec 22, 2006 | 04:48 PM
LS1LT1's Avatar
LS1LT1
Do you need to use a new throttle body or will the stock LS2 one work?
Old Dec 22, 2006 | 04:52 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I think the manifold comes with it and the injectors as a unit, I don't think you can get the manifold alone. But I'm not 100% sure.
Mike, do you know?
Old Dec 22, 2006 | 07:52 PM
NineBall's Avatar
NineBall
Stock LS2 throttle body will bolt right on. Like others said, you need to have the L92 heads (they bolt right onto an LS2) for the L76 intake to work. These heads basically flow like LS7 heads, but are very cheap, less than $800/pair assembled.
Old Dec 22, 2006 | 08:05 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by NineBall
cool website lol
Definitely one of my favorites! Member since 2001, old timer here. Made the switch ls1.com when a bunch of folks did.
Old Dec 22, 2006 | 08:33 PM
Invisiguard
wow, so basically the heads for 800 and intake for 2-300 and swap over our injectors/TB and you basically get LS7 heads/intake on a C6??
Old Dec 22, 2006 | 09:35 PM
mikesul's Avatar
mikesul
The manifold can be ordered "bare". Stock T-B will work fine. Complete manifold comes with new T-B, fuel rails, and 40# injectors (larger than stock). Heads will need stronger (dual) springs and milling to restore compression ratio as combustion chamber is larger (70cc vs. 65cc)
Joe G- have spoken w/Barry and will take him my heads and discuss what to do to get the most from them. Then probably to H-P Sales for install and cam.
Price of heads/complete manifold @ Fred Beans=$1360.
Heads also need "offset" intake rockers as they don't come with the heads. Stock exhaust rockers can be switched from "old" heads.
Old Dec 24, 2006 | 04:33 AM
Luftwaffe35's Avatar
Luftwaffe35
St. Jude Donor '10
Default What are the part numbers for the L92 and L76?
Will these bolt straight onto a stock LS2? Is there anything I should be concerned about, if I was to have these installed on my car?
Is there a significant power increase over stock? I thought I read someone referencing an article with test results. I'm all for power increases from simple bolt on parts.
Old Dec 24, 2006 | 11:26 AM
danielschulzjr's Avatar
danielschulzjr
how can you tell if you have the later heads are they on production cars after a certain VIN or strictly replacement pieces?
To Cool Thread on L-76 Intake Production
Old Dec 24, 2006 | 01:07 PM
Invisiguard
no, these heads/intake are not on any LS2s, they are only available right now sold as the heads amd intake by themselves AFAIK
Old Dec 24, 2006 | 03:32 PM
LS1LT1's Avatar
LS1LT1
No, what I meant was that the intake only fits on 6.2L heads, when I said the term 'later' I was simply referring to these newer heads and the new motors in the Escalade/Yukon Denali etc not that there was any change in the current C6 LS2 heads, those are all the same from 2005-2007.
Old Dec 24, 2006 | 04:25 PM
Luftwaffe35
St. Jude Donor '10
As a follow up, I found the following part numbers at the GMPerfromance Parts website. http://www.gmperformanceparts.com/Pa...l.jsp?engine=2
L92 Heads = 12582713
L76 Manifold = 12590123
The website is pretty cool. You can build a crate engine and then check the published Torque and Horsepower for that configuration. According to the website. By just adding the heads and manifold to a stock LS2 the dyno chart shows a peak horsepower rating of 440 at 5800 RPM. Sounds good to me!
