Ported TB; now car doesn't start!!!
Old Dec 29, 2006 | 08:19 AM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
Default Ported TB; now car doesn't start!!!
TB was disasambled, ported front and back but not the closing area of the plate. Throw code of TPS and Control module of actuator, I think the code are 2105 and 2135.
I erased them and did not help. I reprogrammed the ecu with LS2 Edit and did not help either. The car won't even crank.
Any ideas???
Thank in advance.
F Alonso
Old Dec 29, 2006 | 08:46 AM
MR Z's Avatar
0MR Z
Former Vendor
Make sure it plugged in properly and then also check to make sure when you installed the TB back on that it made a good seal. The car may also be creating a vacuum leak.
Old Dec 29, 2006 | 01:10 PM
cbrf4i1's Avatar
cbrf4i1
Originally Posted by F Alonso
TB was disasambled, F Alonso
what do you mean by "disasambled"? the ETC isn't meant to be taken apart if that is what you disasambled, it is a non serviceable item if i am correct.
Old Dec 29, 2006 | 01:15 PM
UDRIVESLOW's Avatar
UDRIVESLOW
Do You Have Access To A Tech 2 And Candi Module?
Some Times There Are Codes Kicked Into The Other Modules
When The Pcm Is Replaced/ Reprogrammed...
May Need To Reset All Codes In All Modules...
You May Need The Theft Relearned...
Where Are You Located??
Udriveslow
Old Dec 29, 2006 | 01:18 PM
UDRIVESLOW's Avatar
UDRIVESLOW
Also Make Sure Battery Voltage Is Okay
Udriveslow
Old Dec 29, 2006 | 01:40 PM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
I am in Puerto Rico
I might need to erase code with a better tool than a Actron Scanner from PepBoys. I reconected the batery without the TB installed. Maybe that is the problem.
Old Dec 29, 2006 | 02:05 PM
excessive81's Avatar
excessive81
the car won't crack at all...that seems strange
Old Dec 29, 2006 | 02:48 PM
UDRIVESLOW's Avatar
UDRIVESLOW
Its Happened To Me Before..i Had To Move One And The Pcm Was Out And Some Of The Sensors Were Disconnected..
Once I Connected The Batt. To Put The Windows Down...
Thats When It Kicked The Codes....
Do You Have A Dealer Where You Are?
You Need To Reset All Modules..
Not Sure If A Aftermarket Scanner Will Work...
Udriveslow
Old Dec 29, 2006 | 09:47 PM
uberC5's Avatar
uberC5
Can the C6 ECU be reset like other OBDII ECU's?....Disconnect negative terminal, discharge soft memory by putting a drain on system (ie. step on brake pedal for 30 sec.), then reconnect negative terminal? I know when I have done this to my other vehicles, the codes are definately cleared. Saves alot of trips to dealer when wifey fails to tighten gas cap all the way....
BTW, this also leads to a delay in starting after reset. My Subaru will crank for 10+secs after an ECU reset
Old Dec 29, 2006 | 10:59 PM
shurite44's Avatar
shurite44
I agree, I would disconnect the negative on the battery and try again. I have solved a few problems that way on C5's and my C6.
Old Dec 30, 2006 | 01:57 PM
UDRIVESLOW's Avatar
UDRIVESLOW
no..
disconnecting the batter will do nothing to clear the loss of communication codes and the big one is the theft.. once its lost the information it needs for theft it needs to be relearned..
some of the tuners have run into this prob..
i fix it with my tech 2 /not sure if you can fix it without tech 2(using ls2edit)...i tryed to do it last night with out the tech 2 and couldnt...
mabe some one else knows how
i got tired of messing with it and relearned it with tech 2.. sorry..
udriveslow
Old Dec 31, 2006 | 12:35 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Describe your disassembly of the Throttlebody, please.
I'll bet you took the TB blade out and put it back in slightly off center. Also, did remove any portion of the throttle shaft?
I personally ruined 5 TB's in TB porting R&D before I figured out what I did wrong. The LS2/LS7 TB does not like TB shaft mods and you have to be real careful with TB Blade removal and reinstallation. If it's even slightly off you will throw p2135 codes. I know you'll say the codes thrown don't relate to the TB blade or airflow errors... but the fact is that I have 5 of those TB's with the same problem in my "parts bin of shame". If the shaft was cut in half the TB blade is impossible to realign in my opinion.
To Ported TB; now car doesn't start!!!
