A6 mechanicals
Old Dec 31, 2006 | 08:53 PM
mrigas21's Avatar
mrigas21
Default A6 mechanicals
After reading several threads about the new 6 speed auto, I still have a few questions.
1) does it still use a hydraulic torque converter or an electronic clutch like BMW's SMG
2) when in D or S and you dont use the paddles, is the shifting as smooth and almost un-noticable like the old A4?
thanks
mike
Old Dec 31, 2006 | 09:56 PM
calemasters's Avatar
calemasters
thanks
mike
Fluid filled torque converter. The clutch packs apply and release is controlled by the solenoids via the PCM.
Like the 4L60-E, shift feel is a function of engine load and throttle position
Old Dec 31, 2006 | 10:37 PM
Vette_DD's Avatar
Vette_DD
2. No, not quite as smooth and unnoticeable as the A4 when in Sport mode and not using the paddles. Slightly smoother and less noticeable when in "D."
Old Dec 31, 2006 | 10:50 PM
haljensen's Avatar
haljensen
The 6 Auto is an AUTOMATIC trans with a torque converter, not an SMG. It's the same as the Automatic 4 except for 2 more speeds and an additional way of selecting gears.
Old Jan 8, 2007 | 09:36 PM
2006c6keller's Avatar
2006c6keller
At times the A6 trans can be smooth and at other times it can "hammer" you. GM seems to be "protecting the warranty" with this transmission. There has been alot of threads on rough shifting and momentary stalling. The problem of tuning when they can finally solve the torque management problem may void the warranty. Unless GM takes a different position and give us new problem solving downloads, we are stuck with their indifferent about our cars, not theirs now. There was talk about tighting up the shifts and different hydrolicis, it seems to be all talk from what the 07's are saying. Torque management is set a 281 ft lbs of torque but the trans can handle 580 I believe. I'm going throught the same problems.
To A6 mechanicals
