2007 c6 what normal temp
Old Jan 3, 2007 | 07:01 PM
Armored Saint's Avatar
Armored Saint
Default 2007 c6 what normal temp
I have a new 2007 coupe and was wondering what normal intown coolant temp would be. I have noticed that my temp is 2 clicks left of 220. So it looks like its around 210 in town.. That seems kinda high to me, is it normal. I have not noticed the fan come on.. At what temp will the fan come on?
Old Jan 3, 2007 | 07:11 PM
noel48's Avatar
noel48
St. Jude Donor '14
The fan on my '05 kicks in at 216.
Old Jan 3, 2007 | 07:12 PM
Evilways's Avatar
Evilways
After a hard run my car runs between 210-220 for awhile, especially if I'm in traffic. It's hard to get used to, so I'm going the stat and tune route, hopefully keeping it under 200 all the time.
Old Jan 3, 2007 | 07:19 PM
ZO6Gal's Avatar
ZO6Gal
This is really interesting timing as I signed into the forum to post the same thing for my '06. I hang around 215 while sitting at a light waiting for it to change. Cruising is around 192. From these other responses, I guess that is a normal range. It is also nearly 75 degrees here in NC too which may have something to do with it. My fan hasn't come on yet like it does in the summer so I feel better about it now.
Old Jan 3, 2007 | 07:23 PM
VET4LES's Avatar
VET4LES
It's normal, might get a little higher in warm weather.
Old Jan 3, 2007 | 07:25 PM
Silver05GTO's Avatar
Silver05GTO
My normal highway temps are upper 190's, once I'm on slower side roads and traffic temps are in the 210+ range.
Old Jan 4, 2007 | 08:53 AM
TrackNoob's Avatar
TrackNoob
One of the first things my dealer mentioned during the checkout with me even before we started the car was the fact it builds to temp quickly, runs 'hot' (200), but it is normal. He not only sells them, but drives and owns one.
Over a year later I can attest that my car runs 195-205, and never gets above 215 or so no matter what, and oil temp is usually 220 or so.
So they run warm, but have good thermal capacity.
Old Jan 4, 2007 | 09:12 AM
beepster's Avatar
beepster
Your temps are normal. These engines are designed to run hot in order to burn hydrocarbons thus reducing emissions and satisfying the EPC.
Living in FL, I could not get used to these high temps so I installed a 160 deg stat. I now cruise @ 178-180, but still go 210-215 in traffic. Fan adjustment & tune should get this to 195-200. I'm more comfy with these temps.
Old Jan 4, 2007 | 05:30 PM
fergy flyer's Avatar
fergy flyer
Mine ditto's these numbers.
Old Jan 8, 2007 | 09:01 PM
2006c6keller's Avatar
2006c6keller
The only problem with a 160* thermostat is when you go into the mountain areas your heater output will not be very hot, a downside. The wife will have cold feet and you know how that goes.
Old Jan 8, 2007 | 09:50 PM
dennis50nj's Avatar
dennis50nj
heated seats
Old Jan 8, 2007 | 10:24 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
The temp on my 06 C6 is around 215 in traffic and 195 on the highway, same for my 05 GTO. My 97 z28 with the LT1 would run up to 230 in traffic!
Old Jan 8, 2007 | 10:31 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Warm heart?
190s while cruising and 210-220 while at a light is what I'm seeing - normal.
Old Jan 9, 2007 | 04:09 PM
andreas g.'s Avatar
andreas g.
I run a 160 stat and live in calif, but I ski in utah. I've never not been warm enough up in the snow. BTW, you mean to tell me that 160 degrees of heat in your car isn't enough to keep your feet and everything else warm??? As to your original question, your temps are normal. If your plan is to leave the car stock then leave the stat alone.
On the other hand if modding is in your future,ie H/C headers, manifold
like I did or S/C then a 160 stat with tunning is in order. The reason you don't hear the fans is because they just don't go on full blast at a certain temp, like the C5's did, they cycle on by percent as temps go up or your using the A/C. Mine runs at 180-185 on the highway and never gets over 203 in town, even in vegas in july.
Old Jan 11, 2007 | 03:51 AM
joela's Avatar
joela
hot enough to sweat my A$$ off and i have to turn it down.
To 2007 c6 what normal temp
