Paddle shift pattern modifications possible?
Old Jan 10, 2007 | 07:51 PM
Lazer300's Avatar
Lazer300
Cruising
Default Paddle shift pattern modifications possible?
On a 2006 coupe with paddle shifters, how can you modify which paddle handles upshift versus downshift? I want the current right side downshift (behind the wheel) to become upshift. I don't want to use the current upshift buttons at all (front of wheel thumb buttons). I just want to use the current left side (behind the wheel) to handle downshifts and the right side to handle upshifts. Why? Since 2004 I've also owned an Audi S4 with paddle shifters and this is the pattern (which I like). Going from car to car I have different shift paddle functionality...and occasionally downshift when I need to upshift...ouch!
Old Jan 10, 2007 | 09:33 PM
Hoonose's Avatar
Hoonose
Do a forum search as someone here has already done just that!
Old Jan 10, 2007 | 10:13 PM
dbratten's Avatar
dbratten
Here's my writeup -- http://web.mac.com/dbrat10/iWeb/C6-A6/index.html -- and you can email any questions you may have. I really like the change.
--Dan
Old Jan 10, 2007 | 10:53 PM
LS1LT1's Avatar
LS1LT1
Old Jan 10, 2007 | 11:18 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
--Dan
Great write-up.
Old Jan 11, 2007 | 03:57 AM
shockwaveharry's Avatar
shockwaveharry
I love the write up, Dan.
This link has a wiring diagram that may also be helpful:Reprogram Paddle Shift?
Old Jan 11, 2007 | 09:44 AM
BADC64GO's Avatar
BADC64GO
--Dan
Great write up Dan, thanks. Another on for our new thread called the install bin MODERATORS please
Old Jan 11, 2007 | 02:08 PM
dbratten's Avatar
dbratten
Yes, I incorporated the schematic as my first image in the writeup. It was the thread you cite that prompted the change I made as you'll find in post #22. Glad you liked the writeup.
--Dan
Old Jan 11, 2007 | 08:46 PM
shockwaveharry
Yes, I incorporated the schematic as my first image in the writeup...
Just because I have eyes doesn't mean they work all the time...
Sorry, I don't know how I missed that.
Old Jan 29, 2007 | 12:23 PM
meaniam's Avatar
meaniam
wow what a awesome mod. the paddles the way gm has done it sucks. now i need to get up the nerve to do this. i heard bad stories about airbags and how they store energy, even after disconnecting the airbag
Old Jan 29, 2007 | 06:50 PM
GMautotech's Avatar
GMautotech
Electricity is not stored in the air bag modules. Only in the air bag sensing and diagnostic module (SDM).
Old Jan 30, 2007 | 12:08 AM
cajunspeed's Avatar
cajunspeed
Old Feb 2, 2007 | 01:55 AM
2006c6keller's Avatar
2006c6keller
I'm not doing it, but I would definitely DISCONNECT THE BATTERY before starting the mod. One slip of a tool and you might short something out. Only a foolish person would not disconnect the battery!
Old Feb 2, 2007 | 02:54 AM
dbratten's Avatar
dbratten
That's what my instructions say in the second paragraph: "First thing, a smart person said to disable the airbag in the steering wheel. There is probably a designated fuse for this but I couldn’t tell from the fusebox cover information which one it was so I disconnected the ground wire instead (photo 2). It is there next to the fusebox and takes a deepwell 13mm socket."
So you can call off "*****."
Old Feb 2, 2007 | 10:44 AM
jimmie jam's Avatar
jimmie jam
i have a question on the paddles for you A6 guys. having only driven my car 57 miles, i noticed that the back side of the paddles are not very user "friendly" to the downshift. there is no "flat" surface for you to touch. is this a design flaw or am i not doing something right. "push" forward to upshift, "push" the paddle towards you to downshift. any suggestions or ideas?
thanks
Old Feb 3, 2007 | 02:56 AM
dbratten's Avatar
dbratten
thanks
With my hands in the 9 & 3 o'clock position I find the paddles easy to use as I pull the paddle back toward the wheel with just my fingertips.
I always found pushing the little + tab on the top to upshift to be a pain which is why I changed their action. I can still use the top tabs to reverse the action side-to-side but I find it much easier now to pull the left paddle to downshift and pull the right paddle to upshift.
--Dan
Old Feb 3, 2007 | 03:08 AM
LS1LT1's Avatar
LS1LT1
It's more like a 'pull' the big, semi flat surface paddle towards you, I think it's a brilliant, ergonomically correct design personally.
To Paddle shift pattern modifications possible?
Old Feb 3, 2007 | 06:05 PM
2006c6keller
Hopefully everyone will follow YOUR GOOD instructions. I have seen people work with jewerly on around high voltage and can weld themselves to the circuit and get killed. In addition, some people don't think that these percautions apply to them, I'm sure you have seen and heard of this before. I once saw a person working on a 220v breaker box and shorted the screw driver and he was still standing there petrified after I literally "flew" down the stairs from the second floor when I saw the flash while doing school homework. This is not the first time I have seen people make foolish mistakes and not use common sense. He should have known better to turn the power off; yes, some people like to work the power on, it only takes once. Keep up the good advice and I hope others will follow.
Old Feb 3, 2007 | 06:22 PM
mbonness's Avatar
mbonness
thanks
I had the same issue initially after I bought my A6, I was trying to downshift by pushing against the skinny lever right behind the "+" buttons. It was not until I saw a photo from behind the steering wheel that I noticed the downshift pads located at 3 and 9 o'clock. They are not obvious when looking at the steering wheel from the front but if you put your hands on the wheel and feel around behind it they are not too hard to find.
Old Feb 3, 2007 | 10:03 PM
dbratten's Avatar
dbratten
I am one of those people who changed out plugs and switches in my house with the power on too many times -- but only with 110v. Left me a little addled on occasion but no outward scaring. Back in '67 I welded my Seiko to the car fender and the battery post. Since then no jewelry. Also, with the cost of electronics on new cars I can't afford to be that stupid again. I guess this is a "do as I say, not as I do" thing.
Thanks for your good input. It is much better to be safe.
