Tire Pressure Sensor Band Clamps? - Help
![](/forums/images/ranks/7k-10k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
hey guys, looking to put the tire sensors in my iForged wheels, the DIC is driving me nuts with the "flat tire" warnings.
Does anyone know where I can find tire sensor band clamps? appears i have to band the sensors to the wheels as they sensors wont work any other way
any info is appreciated!
thanks in advance!
James
thanks in advance!
James
James
Here's an old thread about banding sensors in the wheels:
Click for Banding Sensors Thread
Bob
![Flag](https://www.corvetteforum.com/forums/images/smilies/patriot.gif)
![](/forums/images/ranks/100-500.gif)
thanks in advance!
James
thanks in advance!
James
How did you have them in before when you were having trouble??
St. Jude Donor '06
I believe there was a previous thread on a work around if you want to get rid of the dic problem, but do not want to actually attempt mounting inside of the wheels. Place all four of your sensors in a sealed tube (large enough plastic plumbing pipe) with a valve stem installed. After the pvc glue sets, 'inflate' to proper pressure and all four sensors inside will send that pressure to the dic. As long as the tube is somewhere in the car you won't have a dic problem, but of course, you won't have an actual tire pressure reading.
