anyone bypass shift to reverse yet?
Old Jan 11, 2007 | 08:55 PM
LemansC6's Avatar
LemansC6
Default anyone bypass shift to reverse yet?
its obviously possible beings gm did it has anyone figured it out for the 05's yet? it drives me frigging nuts.
Old Jan 11, 2007 | 09:48 PM
EuroRod's Avatar
EuroRod
Me, too. I'd pay good money for a retro system to bypass this stupid, pita requirement for the 05's.
Old Jan 11, 2007 | 11:48 PM
calemasters's Avatar
calemasters
So you want to be able to shift into Reverse while moving forward?
Good luck.
Old Jan 12, 2007 | 06:52 AM
timd38's Avatar
timd38
Good luck.
No, I think they are talking about putting it in reverse when you park it. After you put it in reverse, you cross your fingers and hope it takes so that the battery is not dead when you get in the next time. 05 model only.
Old Jan 12, 2007 | 07:19 AM
corvette-pilot's Avatar
corvette-pilot
Wow, that's a nice option
Old Jan 12, 2007 | 08:49 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
special rpo code.
i wonder if an '06+ reverse sensor will work on the '05. it's my understanding the '05 has two transmissions sensors. any idea how many the '06+ has ?
Old Jan 12, 2007 | 09:42 AM
Hoonose's Avatar
Hoonose
The '05 MN6 needs to see reverse gear for at least a few seconds before you exit the car.
You can shut down while in reverse, or you can shut down then shift to reverse. The first way is preferable, but not required.
After a few seconds in reverse after shutdown, you can move the shifter to any gear you want and exit the car. Use the parking brake of course. You can leave the car in any gear as long as the reverse gear has registered with the shut down sequence and the BCM. The new reflash helps with this.
Just make sure that the DIC message to 'shift to reverse' doesn't appear before you exit your car, and you're good to go.
I hope this helps.
Old Jan 12, 2007 | 10:16 AM
LemansC6's Avatar
LemansC6
I hope this helps.
not really. i would still have to put the car in reverse to get out. i only drive this car 1-2 times a week and my other car is also a manual so my habits form around my daily driver and this thing just annoys the **** out of me.
Old Jan 12, 2007 | 10:17 AM
LemansC6's Avatar
LemansC6
we need to find out what it was that gm did in 06 when they bypassed this. heck we could all be dealing with this just because people say get used to it and it could be as simple as the skip shift bypass.
Old Jan 12, 2007 | 10:22 AM
runutzzzzz's Avatar
runutzzzzz
I'm sure it's easy to bypass! I just got used to it and don't feel like trying...
Old Jan 12, 2007 | 10:45 AM
Hoonose's Avatar
Hoonose
Well I just hope that you still have your health!
Old Jan 12, 2007 | 12:15 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It bugs me but I must admit I'm getting used to it. I always parked the C5 in first.
A little info on the legality of it here: http://forums.corvetteforum.com/show...hlight=reverse
The flippin' XM wart bothers me more... I woud like a vendor to come out with a wart removal kit but it would be a limited market.
Old Jan 12, 2007 | 12:34 PM
Hoonose's Avatar
Hoonose
In '06 the column lock was eliminated as the feds allowed.
You just can't remove or bypass the column lock in the '05. (easily)
There would be mechanical and software hell to pay if you did!
Maybe it could be done. Maybe not. It hasn't yet been done.
But it would be a large and technical undertaking, and I don't think that there would be owner support if the price was too high for the conversion.
Most all owners have gotten used to the reverse requirement.
And the BCM reflash is most likely successful in eliminating DBS.
The CAGS was obviously designed with an easy aftermarket bypass in mind...
Old Jan 12, 2007 | 02:53 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
What's the big deal? It's always smart to "park" a manual tranny in gear rather than depend only on the parking brake....same as putting an auto in "Park". So what difference does it make if you use Reverse instead of First? The real PITA with the '05's (& I have one) is that the shut down sequence of the on board electronics is tied to "Shut Down in Reverse" & due to some still unknown gremlin, that doesn't always work, leading to the dreaded "DBS".....otherwise known as Dead Battery Syndrome. If you have an '05 MN6, you should keep a battery charger handy.
Old Jan 12, 2007 | 08:19 PM
black783's Avatar
black783
My 80 C3's parking brake gave out once. I got a knock on my door and some guy tells me the Vette was in the middle of the street! It had rolled into it from my driveway and luckly no one was coming. Since then all my manuals go into reverse before I leave them.
Old Jan 12, 2007 | 09:48 PM
LemansC6's Avatar
LemansC6
i live in florida so pretty much everywhere i go it gets parked in nuetral and e brake goes on as there are no hills. but i guess if its the column lock thats attributing to this then it will be a fairly large undertaking. ive already had the car to the dealership once for a new battery after it left me stranded 3 times in 1 week. it never got reflashed though.
Old Jan 13, 2007 | 09:33 AM
Hoonose's Avatar
Hoonose
There have been reports of the car moving and getting damaged when left in neutral and just the e brake.
Mine included!
To anyone bypass shift to reverse yet?
Old Jan 13, 2007 | 09:39 AM
timd38's Avatar
timd38
Not easy to do because the 05 has the previous generation computer and the 06 has the next generation computer, so you can't just swap out computers. With that being said, I can't believe that someone hasn't found a way to reprogram the 05 computer to eliminate the park in reverse issue. Everyone appears to have solved the skip shift issue........
Old Jan 13, 2007 | 09:57 AM
Hoonose's Avatar
Hoonose
Could be simply numbers. How many '05 MN6 customers will pay for the reverse bypass vs how many manual C5's and 6's for the CAGS?
Or complexity.
CAGS seems to have been designed with an easy aftermarket bypass already in mind.
Old Jan 13, 2007 | 11:48 AM
sjreeh's Avatar
sjreeh
The real PITA in my opinion is having to explain it every time I use valet parking. They have even parked it in 1st after I explained it. Keeping a battery charger at hand isn't always practical. A bypass would be great.
