OBD2 code reader help
Old Jan 12, 2007 | 10:43 PM
GER42's Avatar
GER42
Default OBD2 code reader help
I got a new code reader today. It says to connect with ignition off then turn the ignition on but do not start the engine. On a C6 does that mean AUX on?
Old Jan 12, 2007 | 10:56 PM
mikesul's Avatar
mikesul
Yes.
Old Jan 13, 2007 | 12:11 AM
cbrf4i1's Avatar
cbrf4i1
no, it doesn't mean aux. hit the start botton, but don't start it. (if you have manual leave the clutch alone)...it is kinda like key on engine off, if you know what i mean.
Old Jan 13, 2007 | 01:54 AM
vette6500's Avatar
vette6500
I think you hold the bottom part of the start button for few seconds and it goes into the on mode.
Now, where is the connection for the OBDII reader on the C6?
Old Jan 13, 2007 | 03:38 AM
DJackman's Avatar
DJackman
The connection is on the bottom of the dash right above your knee. Look for the slot.
Old Jan 13, 2007 | 03:59 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
It's mean push the "ACC" button then turn off the car.
Old Jan 13, 2007 | 05:56 AM
Ranger's Avatar
Ranger
Push and hold down the lower edge of the start switch. Hold for about 10 seconds. The computers will fire up without the motor starting. This gives access to all the gauges (coolant and oil temp, for example).
It also causes sensors to report to the ECU/PCM, which allows the ODBII reader to capture data.
Ranger
Old Jan 13, 2007 | 07:27 AM
VET4LES's Avatar
VET4LES
Ranger
That's the way I use my Innova 3110.
Old Jan 13, 2007 | 08:56 AM
GER42's Avatar
GER42
That's what I just got.
Thanks for the help
Old Jan 13, 2007 | 09:08 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
that's how i read mine with my innova 3030 reader.
i leave it in reverse, plug the scanner in, hit the acc button, let it read, then unplug it and press the off button when done.
To OBD2 code reader help
