Coating Cats ??
Old Jan 13, 2007 | 06:01 PM
Beatinu's Avatar
Beatinu
Default Coating Cats ??
Ok from what I think I understand. Cats must get hot to work is that correct so far. Cats also are the main culprit for cabin heat. When coating headers do you normally coat the cats as well. If not would it be a good Idea ? The heat would stay inside the cats but limit the exterior heat. What do you think ???
Old Jan 13, 2007 | 06:07 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
My LG cats are coated and I've had no problems. One guy said that if they get too hot, they cause the computer to dump more fuel, but my mileage didn't change.
Old Jan 13, 2007 | 06:44 PM
cbrf4i1's Avatar
cbrf4i1
tommy, there is no cat temp sensor that tells the pcm the cats are too hot. pcm use other temp sensors to make this assumption, so coating the cats will not cause the pcm to dump more fuel and i am not suprise your mileage didn't change. btw thoes coat headers / x pipe looks great.
Old Jan 13, 2007 | 06:48 PM
TommyV's Avatar
TommyV
Thanks for the info.
Old Jan 13, 2007 | 08:01 PM
timd38's Avatar
timd38
Question, if the cats are coated and get hot, could they cause a fire? Not trying to be difficult, just trying to understand.
Old Jan 13, 2007 | 08:05 PM
TommyV's Avatar
TommyV
The coating may only get the internal temp up, the outside should be cooler than non coated.
Old Jan 13, 2007 | 08:07 PM
cbrf4i1's Avatar
cbrf4i1
it is hotter inside the pips not the outside, which helps reduce cabin heat to a certain degree, so it shouldn't cause any fire from the coating.
Old Jan 13, 2007 | 09:14 PM
KILR-Z51's Avatar
KILR-Z51
Do the LG come coated or how much more did you have to pay for Jet coating.
Old Jan 13, 2007 | 10:13 PM
TommyV's Avatar
TommyV
It was about $350 to have them Jet Hot coated. You can buy them from LG already coated also.
Old Jan 14, 2007 | 11:56 AM
hbvette07's Avatar
hbvette07
do you guys prefer the ceramic coating or the titanium?
To Coating Cats ??
