C6 tail light pattern
Old Feb 4, 2007 | 09:44 PM
2LT-Z51's Avatar
2LT-Z51
not sure what you need to know.... the 3157 bulb has two states.... stop light (27 watts) parking light (8 watts)
if your going to use the stock wiring the signal from the car will dictate what the bulb shows... (stop or parking)
ie if it gets a signal for the 27 watt it will be bright
are you looking for a lens pattern?
sorry i don't have the stock lens on my car and to much trouble to reconnect.... i did take a few when i first got my car....
here is a stop pic....
parking and reverse lights
Old Feb 4, 2007 | 11:04 PM
Oznium.com's Avatar
Oznium.com
2nd Gear
Ok, I will try to be more clear.
I need pictures of the following situations:
1: off
2: running lights on
3: brake pedal depressed
4: running lights on, left signal on / right signal off
5: running lights on, left signal off / right signal on
6: brake pedal depressed, left signal on / right signal off
7: brake pedal depressed, left signal off / right signal on
Or a video would work too.
