Best battery for the C6
Old Jan 24, 2007 | 04:26 PM
Rada 1's Avatar
Rada 1
Default Best battery for the C6
I have used Optima red tops in my C5s, will this battery fit the C6 and is it the best battery for it, I have heard pos and cons about the Optima, I have had good luck with them over the years.
Old Jan 24, 2007 | 05:14 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Unless you're running a powerfull aftermarket stereo system. I'd say the OEM is more than sufficient.
Old Jan 24, 2007 | 05:44 PM
calemasters's Avatar
calemasters
I perfer the AC Delco Professional Series battery.
I purchased a new Optima Red Top and it would not start the car. The new Optima was dead and would not take a charge. Some guys say the Optima does not last long.
Old Jan 24, 2007 | 09:02 PM
johnnyhulk's Avatar
johnnyhulk
C.O.W. suggested a marine type battery for my c6 conv. with manual tran. because i do not use the car that often. They said it would tend to hold it`s charge longer. Can anyone suggest one?
Old Jan 24, 2007 | 09:43 PM
2JZFAN's Avatar
2JZFAN
my optima yellow has lasted forever.. i let it sit for over a year then hooked up my CTEK and the battery hasn't let me down yet. I really like the high cold cranking amps and overall couldn't be more pleased. I've had it for over three years now.
Old Jan 25, 2007 | 01:03 AM
Minkster's Avatar
Minkster
I've had a red top in mine since Aug '05, and it has done well.
Old Jan 25, 2007 | 03:56 AM
rzone's Avatar
rzone
I ran my stereo for a couple hours the other day while cleaning
my 2007, the "low battery" message came on in the DIC, then
the car would barely start.
I have the BOSE, but would not think it would kill the battery that
fast.
I wonder if the stock battery is just a weak model.
Old Jan 25, 2007 | 04:11 PM
Bandit1's Avatar
Bandit1
Here you go..........
http://forums.corvetteforum.com/show...83&forum_id=74
Old Jan 25, 2007 | 04:19 PM
vette-oholic's Avatar
vette-oholic
u guys had to replace your batteries already??
Old Jan 25, 2007 | 06:06 PM
k0bun's Avatar
k0bun
fast.
Hmm. I do that all the time with my '07(base stereo) and have no problems. It's usually on for 1.5-3 hours depending on what I'm doing. I just set it to accessory mode. It'll turn itself off after about 20 min. Then I just flick it back on again. Never had any problems starting her up.
To Best battery for the C6
