Hi Guys, the install instructions for the APS C6 drop in twin fuel pump system has just been completed, see link below for details. This new fuel system has been designed to cater for high powered twin turbo/supercharged engines and has sufficient fuel flow to comfortably cope for up to 1000 hp applications. Just add a set of 60 lb Siemens injectors and you good to go, all other hardware required is supplied in the APS fuel system, enjoy!
