Clanking sound. Help!
Old Jan 26, 2007 | 11:35 PM
ZO6Gal's Avatar
ZO6Gal
Default Clanking sound. Help!
There is a clanking/squeaking sound going on in the rear of my car during up/down movements. It is very clear if I go to the rear of the car and force the car to make up/down movements. It is very annoying while driving. Maybe a bad shock, spring? Anybody have any ideas? Thanks.
Old Jan 27, 2007 | 06:14 AM
calemasters's Avatar
calemasters
Loose stabilizer bar/link or shock. Maybe.
Old Jan 27, 2007 | 08:00 AM
VET4LES's Avatar
VET4LES
It could be a lot of things. The best bet is to let the dealer take care of it under warranty.
Old Jan 27, 2007 | 09:30 AM
06C6Z's Avatar
06C6Z
Old Jan 27, 2007 | 09:43 AM
stabori's Avatar
stabori
St. Jude Donor '08
Possible rear sway bar
Old Jan 27, 2007 | 09:56 AM
Radical05's Avatar
Radical05
Default Z51
Is this a Z51? Possible toe link requiring grease or like others stated loose sway bar/part. Unless can identify yourself and correct easy take it to the dealer for warranty work.
Old Jan 27, 2007 | 03:47 PM
ZO6Gal's Avatar
ZO6Gal
I took the car this morning to a friend's shop who happens to have a drive up lift. When we got it up there and maneuvered it up and down with the sway bar, we decided it was definitely the bushings in the lower control arms. So, we sprayed an entire can of lubricant on each side of the rear and after an hour, the noise was gone. It has not been really cold here in North Carolina until this week and I think it was just that affecting the bushings. Hopefully, that will take care of it but if not, I will take it to the dealer for them to deal with. I'm just thankful it wasn't something really bad. All is quiet now and I drove it a good bit afterward to make sure. Thanks for your responses.
To Clanking sound. Help!
