Telescopic Column Quit Working
Old Jan 27, 2007 | 03:22 PM
Randude's Avatar
Randude
2nd Gear
Default Telescopic Column Quit Working
Hey there,
99 C-5 Coupe; Telescopic column quit working the other day for NO apparent reason. The wife drove it one day, using her memory setting. Everything worked fine. The next day i get in it, set MY memory,...the seat, mirrors, and AC all set, but the steering column did NOTHING. No movement using the manual button either. This sux. Luckily, it somehow stuck on my setting
Any quick (reset) fixes here? I'm hoping that it's nothing serious.
THANKS in advance for your help.
Old Jan 27, 2007 | 04:13 PM
noel48's Avatar
noel48
St. Jude Donor '14
Try the C5 section.
Old Jan 29, 2007 | 09:54 AM
Bandit1's Avatar
Bandit1
My 99 did the same thing. Took the column cover off, cleaned, tightened and lubricated the worm gear, and whala it worked ever since then. Hope this helps.
Old Jan 29, 2007 | 07:10 PM
06C6FVR's Avatar
06C6FVR
Tap the button toward you 4 times in rapid succession, then push it towards the dash(some kind of reset). This worked in my 99, and i remember reading that somewhere and thats how i found out.
Daren
Old Jan 29, 2007 | 07:59 PM
Miaugi's Avatar
Miaugi
You might also try disconnecting the battery for 10 minutes. I was surprised on more than one occasion how this seemed to "reset" little problems like this.
To Telescopic Column Quit Working
