Removing brake rotors
Old Jan 28, 2007 | 02:54 PM
ohfiver's Avatar
ohfiver
Default Removing brake rotors
Wasn't there a simple step by step thread with pics. on the forum? If not can anyone suggest a resource for removing and installing brake rotors?
Old Jan 28, 2007 | 03:22 PM
Maalox's Avatar
Maalox
St. Jude Donor '06-'07-'08
I'm not sure if there are step by step directions. From personal experience, once you have the car safely on jack stands, be sure and release the parking brake before removing the rears.
The oversimplified directions are... Put the car on jack stands, remove the wheels, then the calipers and the rotors come right off.
Good luck with your project,
Old Jan 28, 2007 | 03:50 PM
cielosf's Avatar
cielosf
You will need an 18mm wrench or thin vice grips to keep the caliper bollts from spinning. Just removed all four to get everything powdercoated.
Old Jan 28, 2007 | 08:31 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I was going to work on a writeup, but one of my customers just did one that he should be posting soon.
Old Jan 28, 2007 | 09:19 PM
aTX427
Guest
Posts: n/a
Just break off the lock washers on the lugs. They are just installed at the factory to prevent the rotors to fall off on the assembly line. You do not need to reinstall them.
Old Jan 29, 2007 | 05:33 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
On the fronts turn the wheels to get access to the caliper mount bolts, they are on tight with lock tite from the factory. A long breaker bar helps.
On the rear there is less access. If you don't have an impact, you might try a little heat (carefully) to break the locktite the factory installed.
Old Jan 29, 2007 | 10:46 AM
ohfiver's Avatar
ohfiver
Thanks folks, any help is appricated. Corvette Pilot will wait untill I see it befor I start my project. Thanks!
Old Jan 30, 2007 | 05:38 PM
fat bob's Avatar
fat bob
ohfiver, I did this two months ago, replaced the stock rotors with Z51.
From memory, I don't remember sizes but they are standard metric
Fronts... support front of car with jack stands
remove wheels
remove the TOP bolt from the caliper. TOP BOLT ONLY
rotate caliper toward rear of car and when it clears the rotor/pads. slide the caliper toward the center of the car and place on something so that the brake line is not under load, I used another jack stand. The caliper will slide off the bottom pin without removing the bottom bolt.
remove pads from bracket.
remove bolts holding bracket on. As others have said, these will be tight but the large one is torqued to 125 ft/lbs and should come off without too much effort.
remove the flat retainers that hold the rotor on and throw them away.
the rotor will come off easily.
The rears are the same BUT both bolts must be removed from the caliper. make sure the parking brake is off.
install in reverse and be sure to use silicone grease on the brake pins in the calipers and use brake cleaner on the rotors .
Hope this helps you. This was my first disk brake job on cars. I had done them on motorcycles so I was a little nervous but it went very well.
Bob
Old Feb 10, 2007 | 05:46 AM
Jochen's Avatar
Jochen
I have an instruction on my website www.corvettec5.de in german language. But there are a few pictures to check. Just use Bobs written instruction with my pictures...
http://www.corvettec5.de/D/Technical/FDisc.html
Hope this helps!
Jochen
Old Feb 10, 2007 | 06:56 PM
eurostyle's Avatar
eurostyle
Hope this helps!
Jochen
Himmihergotzakramentzefixlujamileckamars chsheisseglumpfaregz.
Old Feb 10, 2007 | 09:15 PM
MWAZ's Avatar
MWAZ
Here's another step by step. http://forums.corvetteforum.com/show...post1558729397
Just got my calipers back from Mike and will be putting them back on this weekend.
Old Feb 10, 2007 | 09:27 PM
07C6NTX's Avatar
07C6NTX
The instructions on the link say to replace the bolts? Call me crazy but I have never heard of that and I dont think I will ever do that......
Old Feb 11, 2007 | 03:10 AM
vlocty's Avatar
vlocty
The service manual states that you are to replace the caliper bracket mounting bolts if they are removed or even found to be loose. Bolts cost about $6 each.
Old Feb 11, 2007 | 11:18 AM
ricatthebeach's Avatar
ricatthebeach
Nice instructions for removing the calipers; but wasn't the thread starter asking how to remove the rotors?
Old Feb 11, 2007 | 12:28 PM
BlackMark's Avatar
BlackMark
Make sure to wire brush all residual loc-tite away on the mounting bolts,apply blue loc-tite and reinstall.The 100+ lb/ft torque on the caliper mounting bracket bolts is a tough one with a short handled torque wrench that fits inside the wheelwell-kinda like doing bench presses with 100 lb dumbells!
Old Feb 11, 2007 | 11:34 PM
DrivnXcitment's Avatar
DrivnXcitment
I've done many disc brake jobs and never have I replaced the caliper bolts. And also never have I had a problem with them. I actually have a drawer full of new ones from when you buy the pads from a dealership they come with the new bolts.
Old Feb 11, 2007 | 11:44 PM
SMOKNC6Z06's Avatar
0SMOKNC6Z06
Former Vendor
Or just drive down to our shop and we can do it for you.
Old Feb 12, 2007 | 11:56 AM
vlocty's Avatar
vlocty
The bolts you are supposed to replace are not the bolts that hold the caliper to the caliper bracket. They are the ones that hold the bracket to the hub. When doing a brake job you do not touch these bolts. You only remove the caliper to caliper bracket bolts.
All bolts deform a little when torqued. The high torque on these bolts does cause them to deform and reusing them can cause stress that could cause the bolt to fail. They are requiring that you replace the bolts in their concerns for your safety.
Also following the service manual when performing your own maintenence is crucial if you want to not void your warranty
Old Feb 12, 2007 | 11:58 AM
MWAZ's Avatar
MWAZ
Are you talking about the smaller caliper bolts or the larger caliper bracket bolts? You only need to remove the two small caliper bolts to replace the pads - not the two large bracket bolts. The smaller ones are only torqued to 25 lb/ft which doesn't stretch the bolt much. The bolts the service manual says to replace are the larger ones that are torqued to 125 lb/ft.
To Removing brake rotors
